Turn signal and brake lights will not turn on Dash, Compatible relays for signal flasher |
juliomagdaleno |
Jan 29 2013, 11:06 AM
Newbie Group: Members Posts: 24 Joined: 8-January 13 From: austin Member No.: 15,350 Region Association: None |
I have a 1974 porsche with a 2.0 I am trying to get to pass inspection. I purchased the car about 3 weeks ago and am trying to work out all the bugs. The turn signals did not work and i fixed the problem, they all work now including the hazards. The problem is the turn signal light on the dash does not blink. The bulb is good and there is no power going to the bulb. It is a blue wire with white marks that comes from the relay with no power. Is it the relay that is bad, i tried to find the relay local, Austin TX, and have been unsuccessful, guess i have to order the part. I tried using a Tridon EP26 relay but i guess this is not the correct relay. Anyone have any suggestions, is it the relay or should i be looking at something else.
I also have a problem with the parking brake light, is there a relay for this and what should i look for to make this light turn on. thanks |
Lo-Fi Version | Time is now: 18th May 2024 - 11:13 AM |
