Hand Brake Dilema, Flashing Red Lights |
martinef1963 |
Nov 12 2004, 03:00 PM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Hey gang - I have a 72 914 that when I disengage the emergency brake (two piece lever) the flashing red lights in the dash won't turn off.
After I disengage to brakes - I have to physically push the lever away from the driver's seat so they can turn off, but once I let go of the lever the problem returns - any help on what I need to do to fix this? thanks, (IMG:style_emoticons/default/headbang.gif) |
Joe Ricard |
Nov 12 2004, 03:02 PM
two options. bed the hand lever to actuate THE SWITCH. or relocate the switch (just kidding).
Kargeek |
Nov 12 2004, 03:06 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
There is a pin switch similar to one located in the door jam that works the dome light. It is located below the emergency brake handle. Check this switch- the brake handle pushes against it and breaks it from grounding and working the light.
martinef1963 |
Nov 12 2004, 03:12 PM
skline |
Nov 12 2004, 03:13 PM
If all of that does not turn the light off, then you may have a problem with your M/C. Check that next.
F4i |
Nov 12 2004, 03:18 PM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
(IMG:style_emoticons/default/agree.gif) there is a reset button on it. Check for the REAL problem though.
jim912928 |
Nov 12 2004, 03:31 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
the switch the handbrake hits is on the floor pan support brace that goes from the drivers side door to the passenger side door in front of the seats. It is just a switch like in the door jam that the handbrake lever goes against when down.
McMark |
Nov 12 2004, 04:22 PM
QUOTE(F4i @ Nov 12 2004, 01:18 PM) (IMG:style_emoticons/default/agree.gif) there is a reset button on it. Check for the REAL problem though. Not all master cylinders have the reset button. Someday I'll have told everybody and people will start saying "Check you M/C for a reset button, some have them." (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 08:59 AM |
