jack post restoration, how does this sheet metal layer up? |
qa1142 |
Nov 12 2004, 08:13 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Well
Dug into left jack point today. metal is layered there??? looks like long goes behind the rear sub-frame??? Top layer is rusted through in spots. Clean solid metal all the way around where the jack post support was spot welded to the subframe. Surface rust cleaned up well under the long/subframe. If I weld this 1/2 post support in, will that be good enough? What is top layer here, the rear sub-frame? what bits would I need to patch in clean metal here?? Take a look at these pictures... Attached image(s) |
qa1142 |
Nov 12 2004, 08:15 PM
another view
qa1142 |
Nov 12 2004, 08:17 PM
If I por15 it and weld this piece in....
ChrisFoley |
Nov 12 2004, 09:50 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Thats what I would do ... unless you want to start a big project. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif)
qa1142 |
Nov 13 2004, 09:12 AM
(IMG:style_emoticons/default/icon_bump.gif) Only one reply? What happened you all asleep? (IMG:style_emoticons/default/laugh.gif)
Lou W |
Nov 13 2004, 03:35 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
I would think that you would want to make sure that the area is treated with some type of rust stopper, something like Dupont Metal Prep, then primered with weldable primer and then weld the new piece in. (IMG:style_emoticons/default/smile.gif)
Eric_Shea |
Nov 13 2004, 03:41 PM
Put a rust stopping agent (RUST-MORT etc...) in there first. Then POR-15. Then grind away the POR 15 on the areas to be welded. Then Zinc prime those. Then weld that piece you've got in there. Looks like you're on the right track. (IMG:style_emoticons/default/beer.gif) |
Rhodes71/914 |
Nov 13 2004, 03:42 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
QUOTE(qa1142 @ Nov 13 2004, 07:12 AM) (IMG:style_emoticons/default/icon_bump.gif) Only one reply? What happened you all asleep? (IMG:style_emoticons/default/laugh.gif) Seems like sundays are quiet around here, Looks good. |
TheCabinetmaker |
Nov 13 2004, 03:44 PM
Uh, Sean, today is Saturday.
Lo-Fi Version | Time is now: 13th May 2024 - 11:05 PM |
