Well
Dug into left jack point today. metal is layered there??? looks like long goes behind the rear sub-frame???
Top layer is rusted through in spots. Clean solid metal all the way around where the jack post support was spot welded to the subframe.
Surface rust cleaned up well under the long/subframe.
If I weld this 1/2 post support in, will that be good enough? What is top layer here, the rear sub-frame? what bits would I need to patch in clean metal here??
Take a look at these pictures...
