Martini 914 1974, restoration thread |
falcor75 |
Feb 2 2013, 09:09 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Got my first 914 home last monday...barely had time to look at it becuase of work.... was in rougher shape than the pictures I was sent of it before buying it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.964c2.se-15176-1359817741.1.jpg) Spec's: Front glasfibre hood Rear glasfibre hood Front GF bumper (cracked) Rear GF bumper Rollcage Old five point harnesses, will be discarded. Three point belts will be installed (needed to pass Swedish registration) Rebound adjustable red Koni's front and rear Springs "140 lb Weltmeister" Engine overhauled 2001: "Euro" pistons Camshaft, unknown spec. Overhauled heads with new valves and guides Weltmeister oiltrap Flywheel lightened 2 kg's Frontmount oilcoover External oilfilter etc.... It's a pretty rough looking car but the plan is to get it registered (ex California car, I got it from 914er-teile in Germany) and then tear it to pieces and do it right, find all rust, fix it and have it resprayed. Yes, my projects tend to go overboard.... (IMG:style_emoticons/default/biggrin.gif) The long term plan is to build my own version of a "914 RS" in the same kind of way as the 964 RS was made. Original looks, a little bit lighter, a little more power, a little better brakes and handling. |
falcor75 |
Mar 24 2015, 11:29 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/matsgarage.com-15176-1427261358.1.jpg)
Got my dash back from the upholsterer....sooo smooth! (IMG:http://www.914world.com/bbs2/uploads_offsite/matsgarage.com-15176-1427261360.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/matsgarage.com-15176-1427261361.3.jpg) Closeup, he had to lay one seam to either side of the bulge and one across the top but it turned out great. He also did the lower piece but I didnt get any pics of that. (IMG:http://www.914world.com/bbs2/uploads_offsite/matsgarage.com-15176-1427261362.4.jpg) Also got my fresh air box back together. Used some 15x5 mm straight foam cell adhesive strips to seal the motor against the housing and the rest of the seals are from 914Rubber's airbox rebuild kit. Not sure why I cant get the box to clean up, annoying with one half looking ok and the other half looking dirty. Now I'm just waiting for my electrical harness to be finished being refurbished by Kroon Wire Harnesses. They have replaced all the crimped on connectors and exchanged some damaged wires. If you need help with your wiring harness I recommend them warmly. Kroon Wire Harnesses |
Lo-Fi Version | Time is now: 26th April 2024 - 01:24 PM |
