For fellow D-Jet Newbies..., bad fuel line - looked good though... |
potomacmidget |
Feb 3 2013, 04:46 PM
I gotta have more cowbell.... Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States |
Thought I would start up my car today and take a quick spin, been desperate to go for a drive but the weather has not been to good. Started her up and had fuel pour out at the pressure regulator. Thought it was a loose clamp from the cold, tried to tighten it but still leaked. Shut her down and pulled the line - not good. Glad I discovered it in my garage. I replaced some lines last year but looks like I should just do them all in the spring. Just wanted to give a heads up to fellow newbies, the lines may look good but may be rotted from heat or stress..
Attached thumbnail(s) |
euro911 |
Feb 3 2013, 04:50 PM
Replace ALL the hoses, including under the fuel tank! Who knows what condition those are in (IMG:style_emoticons/default/sad.gif)
If you can afford it, replace the plastic lines through the tunnel with Racer Chris' or Rotary'14's SS lines "while you're in there" (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 04:25 PM |
