> Horn question, problem solved!
dfelz
post Feb 6 2013, 07:53 PM
beach bum
I have a 71 that came with no horn pad on the steering wheel. I have a momo wheel and momo hub adapter, but i bought those when my project involved a 72! so now i cant use the hub adapter and therefore also cant use the momo wheel (for now)
So coming out of the wheel is one wire, which i imagine is the horn wire. I have a button (pictured below) i want to rig to the steering wheel. I know the wire currently coming out of the wheel will go to one terminal, but where should the other terminal be connected? grounded on the wheel??
Thanks for the help
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1360202012.1.jpg)
Kirmizi
post Feb 6 2013, 08:17 PM
http://www.914world.com/bbs2/index.php?sho...264&hl=horn (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis
post Feb 6 2013, 08:24 PM
Resident Electrician
Under you steering column, there is a brown w/white stripe wire. If you ground it, the horn will honk. Assuming the system is functional...
dfelz
post Feb 6 2013, 08:39 PM
beach bum
QUOTE(kg6dxn @ Feb 6 2013, 06:24 PM) *
Found it! now working on wiring it up.
Thanks
dfelz
post Feb 7 2013, 05:11 PM
beach bum
Got it sorted out in only two attempts. First attempt left the horn always on once the key was turned, haha, oops. Second attempt involved heat shrink and no short circuiting. had one terminal on the button go to the brown/white wire, and the other terminal was grounded to the chasis through one of the four screws that attach the plastic housing to the wheel center. Had to drill out the horn hole a little bit to fit the button through from the backside. Since it was mostly aluminum, it went smoothly like butter (IMG:style_emoticons/default/biggrin.gif)
Thanks for the help!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1360278668.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1360278668.2.jpg)
- Lo-Fi Version Time is now: 19th June 2026 - 09:17 AM
