A bit of backfire... |
Rusty |
Nov 13 2004, 05:55 PM
Well, I finished the valve adjustment last weekend, and put the valve covers on today. The last valve adjustment I did was... lacking. (IMG:style_emoticons/default/blink.gif)
I started and ran the car for the first time in quite a while. No clackity-clack of my formerly misadjusted valves! It purred, like a sewing machine! (IMG:style_emoticons/default/tunez.gif) I do, however, have a bit of a backfire. Stock, carbed /6... car is still on jackstands, so I haven't driven it yet. Bursch headers. No apparent exhaust leaks. Once the engine is warmed up, the backfire isn't on deceleration. Any thoughts? -Rusty (IMG:style_emoticons/default/smoke.gif) |
J P Stein |
Nov 13 2004, 07:36 PM
Out the tail pipe or out the carbs?
Rusty |
Nov 13 2004, 07:45 PM
Tailpipe... and when it happens, it's a loud pop. I don't think the carbs are sneezing.
GWN7 |
Nov 13 2004, 08:56 PM
Did you retime it? I always thought it was valve adjust, set timing, fiddle with carbs....
Joe Bob |
Nov 13 2004, 09:07 PM
Pop on decel? Exhaust leak...
Rusty |
Nov 13 2004, 09:11 PM
Not on decel. I need to do timing, you're right.
Trekkor |
Nov 13 2004, 09:26 PM
The car has been sitting in storage for some time, right?
Why would it go out of time? I thought you had some water damage issues. Any chance of codensation attacking the motor internally and causing valves to schtick. Can't you run it for 10,20,30 mins and see if it smooths out? (IMG:style_emoticons/default/confused24.gif) Does anyone run engine flush? KT |
Rusty |
Nov 13 2004, 10:02 PM
Yep, it was sitting, but the gas is 10 months old... despite being well treated wtih Stabil. It may just be older fuel.
It certainly ran much better after running for a while. I'm going to try and do an Italian tune-up if the weather is good tomorrow. It's had 2 oil changes in the last 10 miles. -Rusty (IMG:style_emoticons/default/smoke.gif) |
redshift |
Nov 13 2004, 10:04 PM
Rusty, change out that fuel, pronto!
Let's not muck it up... I SAID MUCK! (IMG:style_emoticons/default/smile.gif) Drain it, replace it.. M |
GWN7 |
Nov 13 2004, 10:08 PM
you could drain it down and add some carb cleaner to about 2 gals of fresh gas.....let it run and see how it is afterwards
Trekkor |
Nov 13 2004, 10:19 PM
Yes, good. Run a can of that Berryman's carb cleaner/water remover/FI treatment.
KT |
Lo-Fi Version | Time is now: 13th May 2024 - 03:10 PM |
