'splain me about exhaust systems and heat exchangers..., is this compatible with this and this? |
BritCarJim |
Feb 7 2013, 10:23 PM
Member Group: Members Posts: 98 Joined: 22-January 12 From: Sevierville, TN Member No.: 14,043 Region Association: South East States |
i have a '75 teener here...a 1.8...i bought a set of gently used SS heat exchangers from "a guy" here...in the picture...so, i think it may matter what year exhaust bits i get...'ja?
what gives? |
914werke |
Feb 7 2013, 11:17 PM
"I got blisters on me fingers" Group: Members Posts: 10,042 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
That set are from an earlier car than your 75.
Yes they can work...but you will need to replace/backdate a few items. Muffler, hanger, J tubes, branch pipes, Warm air elbows ect. |
euro911 |
Feb 7 2013, 11:21 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Those are 1.7L/1.8L (pre '75). You'll need a compatible exhaust/muffler and compatible muffler hanger.
Photos courtesy of Jeff Bowlsby's site EDIT: Yes, what Rich said (I forgot about the heater stuff) |
rhodyguy |
Feb 8 2013, 08:44 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
that's my deck in the 2nd picture.
if you are switching your 75', you'll need every item for 74' and earlier. branch ducting, warm air elbows, j-tubes, warm air guides (side and tail shift dr sides are dif) and as noted the correct exhaust/muffler and gaskets. the stub tubes and convoluted he's on the 75' can be a pain to remove. when i did a conv i just cut the the 75' stuff apart with a reciprocating saw and a handfull of metal blades k |
Michelj13 |
Feb 8 2013, 09:15 AM
Member Group: Members Posts: 83 Joined: 29-May 04 From: Torrance, CA Member No.: 2,122 Region Association: Southern California |
Wow, Britcarjim, what great information! I had to learn the hard way. It has been my experience with Porsche, that when you try to make a small modification/swap etc. there is usually a lot more to it than meets the eye (IMG:style_emoticons/default/idea.gif)
zixxv6 |
Feb 8 2013, 09:35 AM
Newbie Group: Members Posts: 7 Joined: 29-December 12 From: midwest Member No.: 15,304 Region Association: None |
Great information/pictures/illustrations.
Is the inner diameter of the actual exhaust pipe the same for 2.0 vs 1.7/1.8 and/or did it change over the model years? |
Chris H. |
Feb 8 2013, 10:19 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I think the consensus has been that the stock 1.7/1.8 pipes are smaller diameter than 2.0, but on the SS ones it's a marginal difference if at all. Might even be the same. Believe there is a whole thread on that as well...
Michelj13 |
Feb 8 2013, 03:02 PM
This photo shows the difference between stock 1.7 and SS HE
Attached image(s) |
BritCarJim |
Feb 8 2013, 07:41 PM
very interesting. as my "handle" and signature would suggest, i am not new to the idea of "more complicated than initially suggested." i just new to that on the 9-1-4.
between this thread and a couple pm's i have the idea that the pre-'75 is more user friendly and that there are more parts available. since i'll be taking everything apart anyway, i think i'll swap. |
poorsche914 |
Feb 8 2013, 08:47 PM
T4 Supercharged Group: Members Posts: 3,087 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Hey, Jim... Shoot a picture of what you have on your 914 currently. Could very well be it has been swapped out at some point (IMG:style_emoticons/default/confused24.gif)
PM me and I'll see what parts I have that you might need. I know I have a good 1.7/1.8 hanger. steve (IMG:style_emoticons/default/driving.gif) |
BritCarJim |
Feb 8 2013, 10:04 PM
hopefully steve i'm gonna get a chance over the weekend to put it up on stands and take a bunch of reference pictures. i'll zap a couple to you when i have them.
i picked up the SS exchanger over in the classifieds without realizing it was for the wrong year...but it was cheap. really doesn't matter because all of the stuff i'll have to swap out...were worn out or FUBARed anyway. no big deal. |
Bleyseng |
Feb 9 2013, 04:54 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
The best part is once you do a complete switchover to the 74 and earlier parts you will have heat. (IMG:style_emoticons/default/smilie_pokal.gif)
DRPHIL914 |
Feb 9 2013, 05:58 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
hopefully steve i'm gonna get a chance over the weekend to put it up on stands and take a bunch of reference pictures. i'll zap a couple to you when i have them. i picked up the SS exchanger over in the classifieds without realizing it was for the wrong year...but it was cheap. really doesn't matter because all of the stuff i'll have to swap out...were worn out or FUBARed anyway. no big deal. I made the same mistake, bought a set ended up it was the 1.8 not 2.0 but does not matter i got such a great deal i just orderd the 1.8 triad to go with it. And got the heater tube parts from someones stash of spares. They were dirty and oily but after a bath with degrease, dawn, and primer and paint good as new. While you are at it get your new hardware and gaskets, and the rubber gromets that go between the tin and the tube AA and a couple others have them new. I forgot mine first time around and had a nice rattle. Just remember the muffler hanger is different as well. I Pw |
zixxv6 |
Feb 9 2013, 07:45 AM
I think the consensus has been that the stock 1.7/1.8 pipes are smaller diameter than 2.0, but on the SS ones it's a marginal difference if at all. Might even be the same. Believe there is a whole thread on that as well... Chris, Thanks for this info on the inner pipe diameter. Jim |
Localboy808 |
Dec 12 2016, 11:43 AM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
TheCabinetmaker |
Dec 12 2016, 11:52 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
That's a late model 75/76. 1.8/2.0.
bretth |
Dec 12 2016, 11:54 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
That is the original 75-76 only heat exchangers. Brett |
rhodyguy |
Dec 12 2016, 12:18 PM
Is that a hole in the top of the upper he pictured? Unless you have more parts not pictured you'll have to go shopping. Again. If you use those you need to source the l&r warm air guides. Hope you didn't pay too much shipping for those.
914work |
Dec 12 2016, 01:19 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
The hole is typ. for this version of HE's its common that all the places circled in red can / will be worn through rendering the the HE ineffective for its purpose.
You can see the collector section missing from one. The specific "J" pipes missing altogether. The Green you should check on ALL HE's for rot / leakage (with perhaps the SSI's an exception) Attached image(s) |
Localboy808 |
Dec 12 2016, 01:20 PM
Is that a hole in the top of the upper he pictured? Unless you have more parts not pictured you'll have to go shopping. Again. If you use those you need to source the l&r warm air guides. Hope you didn't pay too much shipping for those. Yes. There is a hole in that heater shroud. Looks man made or factory but didn't really inspect it too closely. I can't use it because the collector where you mount the muffler is totally different. I paid 30.00 bucks for shipping. And I gave the guy a few bucks for his time. My fault. I didn't know that this variation existed. Now I do. (IMG:style_emoticons/default/sad.gif) Still on the hunt for I guess an early 2.0 exchanger or pipes. If someone wants these LMK! I can't use them. |
Lo-Fi Version | Time is now: 5th May 2024 - 02:41 PM |
