dellorto ?, anti-whistle gaskets and intake to carb isolators |
rhodyguy |
Feb 11 2013, 08:48 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
DRLA45D to be exact. i spoke with a rep @ aircooled.net last week with not so much info provided. are the anti-whistle gaskets used in conjunction with the carb to intake isolators or one or the other?
k |
rhodyguy |
Feb 11 2013, 09:43 AM
can somebody explain where the issue is on the carb bottom that the gaskets fix?
Attached thumbnail(s) |
Mark Henry |
Feb 11 2013, 09:45 AM
It's been almost 20 years since I worked on dells, but I think it's the same gasket. It's a thick rubber like gasket with a couple of tits that fit into the divots that make them whistle.
Feb 11 2013, 09:46 AM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Getting old...cant remember, but trust me, its annoying.
Contact Art Thraen. Rich |
Mark Henry |
Feb 11 2013, 09:47 AM
It fills those cut outs (divots... what ever you call them) at 2:00 and 10:00 o'clock. But it's also the full base gasket with that bit molded in.
rhodyguy |
Feb 11 2013, 10:15 AM
$34.95 a set for of the anti-whistle. ouch! BIG squeeze of the testes with those.
anderssj |
Feb 11 2013, 10:21 AM
Dog is my copilot... Group: Members Posts: 1,661 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
The gaskets isolate the carb from the intake manifold. They are a black rubber-like material, roughly 2mm (or 3/16") thick. Each gasket/spacer has a molded "tooth" that fits into the gap in the base of the carb barrel (circled on the picture). I think I got mine from CB performance years ago (like 30 (IMG:style_emoticons/default/blink.gif) )
I don't think I have a loose spacer laying around--they're all on the car--but I'll try to remember to take a picture next time I have them apart. Hope this helps! Steve A- |
rhodyguy |
Feb 11 2013, 10:29 AM
cb no longer stocks the anti-whistle gaskets. i went thru the gas perc thread and saw the plastic/phenolic spacers but the ones pictured appear to be thicker than the 1/8" description at aircooled.net.
k |
rhodyguy |
Feb 11 2013, 10:45 AM
just got off the phone with art. i was told the 45s and the whistle should not be a issue so that's $40 saved. phenolic intakes to carbs are spendy. i don't want to mess around with the hot fuel with the dels when they go on the silver car. i already use the stock fi phenolics. pm'ed a member from the other thread to see if i can find out where bought his. you reading this george?
rhodyguy |
Feb 11 2013, 10:56 AM
pulled the trigger on the LAST set in stock at ACE. includes the 8 'normal' gaskets. when i deduct the not needed anti whistles from the cost it lessens the pain. thanks for the ACE reminder rich. those 'senior moments' are inconvenient.
mrbubblehead |
Feb 11 2013, 02:19 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
hi rhodyguy, i just replied to your pm. they start at the end of page 8 here http://www.dashman.net/category.html?id=13&pager=8 and continue on page 9. i think mine are 1/2 inches thick. they sure make a big difference on my car.
doug |
Lo-Fi Version | Time is now: 27th May 2024 - 11:19 PM |
