| jbachert |
Feb 12 2013, 12:53 PM
Newbie ![]() Group: Members Posts: 40 Joined: 2-January 13 From: Allentown, PA Member No.: 15,329 Region Association: North East States |
I just picked up a 1973 1.7 liter. This is my first 914 and first Porsche. It is basically rust free. All signs point to this being the original paint. There are some little dings and chips here and there. Sounds like the only rust was the jack plates which were replaced.
As far as I can tell (based on documentation with the car) the original owner owned it for 35 years and then there were two other owners before me, but between the two of them they only put a few hundred miles on it. The owner previous to me had it gone over at Translog in York, PA and the following work was done (these are the highlights): Inspect entire car for rust Compression test - (1) 150 (2) 150 (3) 142 (4) 147 Replace shift bushings Replace jack plates Replace push rod tube seals Adjust valves Replace Valve cover gaskets, replace valve adjustment screws Replace all windshield washer hoses Flush Brake fluid - replaced with ATE Blue Replace fuel hoses at pump and tank Replace fuel hoses on engine There is a fair amount of original receipts, etc with this car. There are some small issues to resolve - for example the high beam indicator doesn't light up when the high beams are on, the light between the seats doesn't light - so maybe some bulbs to replace here and there. Also, locking the drivers door with the key is finicky so maybe it needs some lube or something. Enough with the description....here are some pics: (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i294.photobucket.com-15329-1360695186.9.jpg) |
| KENNY |
Feb 12 2013, 12:59 PM
Member ![]() ![]() Group: Members Posts: 143 Joined: 5-February 03 From: Orlando fl. Member No.: 243 Region Association: None |
Very nice car .
| mittelmotor |
Feb 12 2013, 01:03 PM
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Very nice! Looks super straight and solid from the pics you posted.
Welcome to the board here. 914World is far and away the best, most informative and most helpful forum I've ever been on (Spyderchat, for the MR2 Spyder, is a close second). Questions are answered usually in a matter of hours, if not minutes. --Doug |
| jbachert |
Feb 12 2013, 01:04 PM
At some point I'd like to swap the bumpers to chrome bumpers and add a center gauge console....but it is pretty nice as it is for now.
| tadink |
Feb 12 2013, 01:14 PM
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
| Chris H. |
Feb 12 2013, 01:39 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,081 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Awesome car. Regarding the cosmetic changes, it would also look really cool if you put some steel rims with hub caps on it and returned it to 100% stock. Looks like my old '74...base model with no fogs, console, or sail panel trim. Very clean look. You are missing the top to your center tray that fits between the seats. It's not on a hinge, just has a cushion-like thing that fits over top of the tray. Should be easy to find if you don't have it.
| Kaduku |
Member ![]() ![]() Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
I've seen that car advertised somewhere, can't recall. Congratulations, I hope to get my first 914 and my first Porsche soon too.
| NJ914Guy |
Feb 12 2013, 01:43 PM
Member ![]() ![]() Group: Members Posts: 150 Joined: 30-December 10 From: Deptford, NJ Member No.: 12,546 Region Association: MidAtlantic Region |
Looks like a very solid and original car. Good luck and be sure to enjoy her!
| ArtechnikA |
Feb 12 2013, 01:44 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Assemble your shopping list and come out to Hershey April 20.
There's a thread here for this year's Mid-engine Invasion somewhere... |
| Spoke |
Feb 12 2013, 01:59 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,373 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Very nice car. Can't be a PA car in that condition unless it was never driven in the snow or rain. BTW, where are you located in PA? |
| jbachert |
Feb 12 2013, 02:04 PM
(IMG:style_emoticons/default/welcome.png) Very nice car. Can't be a PA car in that condition unless it was never driven in the snow or rain. BTW, where are you located in PA? Believe it or not, it has always been a PA car (I have the documentation). It must have been garage kept. I live near Macungie. |
| JawjaPorsche |
Feb 12 2013, 02:35 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
| rgolia |
Feb 12 2013, 03:59 PM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
outstanding.....I am not far from you...Doylestown area...perhaps a meet and drive when the weather breaks. I have had my teener since it was new and I had to deal with east coast rust. That looks great.
| SchwarzHorse |
Feb 12 2013, 05:36 PM
of the Moby Gang ![]() ![]() Group: Members Posts: 62 Joined: 19-July 11 From: Thoroughbred, Kentucky Member No.: 13,335 Region Association: South East States |
I looked at the car on eBay before the listing disappeared. Nice Purchase ! Steel wheels with caps ? Yuck, don't make that change - just get that black paint off of those Fuchs - it's proven impossible (obviously) to make the 914 4-luggers look like the 5-pedal-spoke 911 Fuchs. What were the paint-it-blackers at the dealerships thinking in the '70s ?
(IMG:style_emoticons/default/slap.gif) |
| KELTY360 |
Feb 12 2013, 05:59 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,186 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
At some point I'd like to swap the bumpers to chrome bumpers and add a center gauge console....but it is pretty nice as it is for now. Think about painting your bumpers body color. It's a nice look. (IMG:style_emoticons/default/welcome.png) |
| Valy |
Feb 12 2013, 07:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Nice car! The paint is probably not original since the sail panels are painted and not vinyl. |
| tod914 |
Feb 12 2013, 08:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Sharp looking car! Congrads on your purchase. Looks very well taken care of.
| jdlmodelt |
Feb 12 2013, 08:48 PM
James D. Lane ![]() ![]() Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
At some point I'd like to swap the bumpers to chrome bumpers and add a center gauge console....but it is pretty nice as it is for now. I was going to do the center gauge console on mine. mocked it up and felt incredibly cramped in there. I like to open feel I get without mine. |
| KELTY360 |
Feb 12 2013, 09:28 PM
(IMG:style_emoticons/default/welcome.png) Nice car! The paint is probably not original since the sail panels are painted and not vinyl. (IMG:style_emoticons/default/confused24.gif) Black bumpers w/no fog lights are consistent with painted sails in a car w/o the Appearance Group option. Not sure why that would affect the originality of the paint. Sweet looking car! |
| rick 918-S |
Feb 12 2013, 10:52 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,243 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Lo-Fi Version | Time is now: 14th April 2026 - 08:37 AM |
