Need pics |
Need pics |
scotty b |
Feb 17 2013, 11:23 AM
Factory custom color Lilac.
I can't find any pics of this color (IMG:style_emoticons/default/confused24.gif) |
JamesM |
Feb 17 2013, 11:35 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I had a hard time finding any examples when deciding to paint this one for my wife. Not sure if they did an accurate job or not, but took it to Maaco and told them porsche color code 341 and this is how it turned out. The color seems to change quite a bit depending on the light. the only other example of a 914 I was able to find was this one http://www.p914.com/p914-6gt_paint_341_70.htm couple 911s as well... not sure if it is the lighting or color shift from the camera but they all seems slitgly different in pictures http://www.finecars.cc/typo3temp/GB/c5d8256134.jpg http://www.356-911.com/modelinfo/911colour...urple341500.jpg |
scotty b |
Feb 17 2013, 12:03 PM
That GT pics is more like what I was imagining. I found 911 shots but no 914's (IMG:style_emoticons/default/confused24.gif)
I think alot of this may be lighting. This is a 911 pic I found. Same car as the one you posted Attached image(s) |
Feb 17 2013, 12:12 PM
Scott,
Keep in mind digital pics are alot different than real life.. Something about the digital camera seeking a different resolution, bt it does change the color on screen.. rich |
Nine_14 |
Feb 17 2013, 12:27 PM
Member Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany |
JamesM |
Feb 17 2013, 12:31 PM
You can see a bit of the color change just with the 2 shots of that same 911, though I still think mine may be a bit off, hard to say for sure though as I have never seen another example of that color in person and i did not have any samples to provide when i got it painted. In person mine looks a lot like the lower of the 2 911 pics you posted.
They actually shot my car twice as they did not mix the correct color the first time (looked more like aubergine), so i dont have much faith they mixed it completly correct the 2nd time either. Still though, you get what you pay for and for what I paid I think its usable for a while. Curious to see how it holds up. |
JamesM |
Feb 17 2013, 12:46 PM
Scott, Keep in mind digital pics are alot different than real life.. Something about the digital camera seeking a different resolution, bt it does change the color on screen.. rich YUP! Can't trust colors you see on screen, unless your exact monitor and the camera used to take the picture have both been color profiled, you will have all sorts of color shifts across all sorts of ranges. Even profiled, a lot of LCDs cant display certian color ranges properly anwyays. I used to work for EPSON doing QA for product devlopment in their pro photo division. Learned more about color and digital workflow then most people would ever want to know. Really need to see a sample in person, which I have yet to do. |
scotty b |
Feb 17 2013, 12:54 PM
You can see a bit of the color change just with the 2 shots of that same 911, though I still think mine may be a bit off, hard to say for sure though as I have never seen another example of that color in person and i did not have any samples to provide when i got it painted. In person mine looks a lot like the lower of the 2 911 pics you posted. They actually shot my car twice as they did not mix the correct color the first time (looked more like aubergine), so i dont have much faith they mixed it completly correct the 2nd time either. Still though, you get what you pay for and for what I paid I think its usable for a while. Curious to see how it holds up. I can almost guarantee yours is not exactly right. Maaco uses their own line of cheapo paint. The main differnece with cheap paint vs. expensive paint is the toners used, and more importantly the NUMBER of toners used. For example I might order signal orange in PPG's shop line ( lower grade ) and also order it in PPG Deltron ( high grade ) spray both colors, and there will be a significant difference. Reason being the cheaper line will only use 4 toners to achieve the end color, while the higher line will use 10 toners to get the final color. This results in a much more accurate color. |
JamesM |
Feb 17 2013, 01:16 PM
I can almost guarantee yours is not exactly right. Maaco uses their own line of cheapo paint. The main differnece with cheap paint vs. expensive paint is the toners used, and more importantly the NUMBER of toners used. For example I might order signal orange in PPG's shop line ( lower grade ) and also order it in PPG Deltron ( high grade ) spray both colors, and there will be a significant difference. Reason being the cheaper line will only use 4 toners to achieve the end color, while the higher line will use 10 toners to get the final color. This results in a much more accurate color. I expected as much as you do get what you pay for. The Maaco choice was more of a cheap/temporary experiment as my buddy that does body/paint work took a job in Afganistan shortly after this project started. Once he is back for good I will probably look at painting it again though if the Maaco job holds up long enough ill probably get that silver car back to its original ivory white first. If you paint one lilac please post pics and what paint you used, as you have found any examples of 914s in lilac are hard to come by. |
dlkawashima |
Feb 17 2013, 03:50 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/uploads/post-12234-1327829824.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-12234-1361137806.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-12234-1361137807.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-12234-1361137807.3.jpg) |
Luke M |
Feb 17 2013, 03:55 PM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I saw this one a while back. It's on the PMS site. Says it's a little lilac but looks silver to me. It maybe the camera or the way the sun is hitting it.
http://www.patrickmotorsports.com/project/...-914-6-gt-also/ |
scotty b |
Feb 17 2013, 04:31 PM
I saw this one a while back. It's on the PMS site. Says it's a little lilac but looks silver to me. It maybe the camera or the way the sun is hitting it. http://www.patrickmotorsports.com/project/...-914-6-gt-also/ That's not a factory color. It is a color called " A little lilac " It's DUPonts special formula. they have a line called HOT HUES. I shot a Barracuda with it ( blue ). Neat paint. the blue on the 'Cuda almost looked like it had an electric charge to it. I'd like to see that lilac in person to see if it has the same effect |
Lo-Fi Version | Time is now: 18th May 2024 - 10:39 AM |
