> lowering my 914, some wheel work
johnpierre
post Feb 18 2013, 12:32 PM
hey everyone (at least here in los angeles). i want to lower my 73 a little, or at least explore the idea. i want it done as best as possible, i.e. ride quality, steering geometry etc. does anyone know of someone or a shop (here locally) that i can trust and that has plenty of experience doing this on 914s. i also want to strip the paint on my rivieras, and repaint them, i suppose that would just be any paint shop right ?
johnpierre   lowering my 914, some wheel work   Feb 18 2013, 12:32 PM
L73   hey everyone (at least here in los angeles). i wa...   Feb 18 2013, 12:45 PM
johnpierre   hey everyone (at least here in los angeles). i w...   Feb 18 2013, 12:48 PM
johnpierre   by the way does anyone have any opinions on loweri...   Feb 18 2013, 12:52 PM
KaptKaos   If you're in Venice, check in with Alex at Pre...   Feb 18 2013, 01:26 PM
johnpierre   If you're in Venice, check in with Alex at Pr...   Feb 18 2013, 01:49 PM
Tom_T   Otto's in Venice knows 914s well for the suspe...   Feb 18 2013, 02:47 PM
r_towle   Otto's in Venice knows 914s well for the susp...   Feb 18 2013, 05:07 PM
johnpierre   Otto's in Venice knows 914s well for the sus...   Feb 18 2013, 06:05 PM
johnpierre   [quote name='r_towle' post='1822384' date='Feb 18...   Feb 18 2013, 06:06 PM
r_towle   [quote name='r_towle' post='1822384' date='Feb 18...   Feb 18 2013, 06:34 PM
worn   You will need to buy adjustable perch rear shoc...   Feb 19 2013, 01:02 PM
KaptKaos   Otto's in Venice knows 914s well for the susp...   Feb 18 2013, 05:08 PM
johnpierre   Otto's in Venice knows 914s well for the susp...   Feb 19 2013, 01:31 AM
messix   yes if you look at rear part of the front suspensi...   Feb 18 2013, 06:25 PM
johnpierre   man, you guys are the shit. i love this website, t...   Feb 18 2013, 06:58 PM
euro911   Hey JP, you only need an 11mm wrench to lower the ...   Feb 19 2013, 02:30 AM
johnpierre   Hey JP, you only need an 11mm wrench to lower the...   Feb 19 2013, 12:34 PM
johnpierre   Hey JP, you only need an 11mm wrench to lower th...   Feb 28 2013, 06:49 PM
KaptKaos   Gotta love them 'Moons' :lol: :barf...   Feb 19 2013, 12:42 PM
Cupomeat   You are generally constrained to buying a rear sho...   Feb 19 2013, 01:08 PM
Randal   You are generally constrained to buying a rear sh...   Feb 19 2013, 01:18 PM
Cupomeat   Also, I know it was said, but you will need to adj...   Feb 19 2013, 01:51 PM
falconfp2001   You can buy some Bump Steer spacers also. This wil...   Feb 21 2013, 09:00 PM
johnpierre   You can buy some Bump Steer spacers also. This wi...   Feb 21 2013, 09:08 PM
euro911   Here's the tech article on 'How to install...   Feb 21 2013, 10:17 PM
johnpierre   Here's the tech article on 'How to instal...   Feb 22 2013, 03:01 AM
johnpierre   Here's the tech article on 'How to instal...   Feb 26 2013, 05:29 PM
jdlmodelt   I'm hoping changing the tires will level her o...   Feb 26 2013, 08:36 PM
jmill   If you remove the adjuster bolt you can pop the ca...   Feb 26 2013, 10:06 PM
jdlmodelt   If you remove the adjuster bolt you can pop the c...   Feb 27 2013, 04:19 PM
- Lo-Fi Version Time is now: 6th July 2025 - 05:21 AM
