Throttle sticking BUT I have new cable....? |
lennyhope |
Feb 20 2013, 03:13 AM
Member Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England |
I have fitted a new throttle cable and it is routed correctly, however it is still sticking... Any suggestions? If it is the pedal bush, how easy are they to fit?? Are there any fitting guides out there?
JawjaPorsche |
Feb 20 2013, 06:31 AM
I have fitted a new throttle cable and it is routed correctly, however it is still sticking... Any suggestions? If it is the pedal bush, how easy are they to fit?? Are there any fitting guides out there? Do you have the original gas pedal? A lot of them get real floppy at the hinge area and cause the pedal to rub. |
cary |
Feb 20 2013, 06:36 AM
Need a little more detail.
Sticking at full throttle, hanging up and not returning to the closed position, etc. |
lennyhope |
Feb 20 2013, 06:46 AM
Snagging / dragging every now and then...
cary |
Feb 20 2013, 07:01 AM
How do you get it back into the correct position.
With the throttle pedal or by hand at the throttle body? |
rgalla9146 |
Feb 20 2013, 07:09 AM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
DBCooper |
Feb 20 2013, 07:33 AM
Disconnect the cable at the throttle body, hlld the cable and have someone push the gas pedal, see where it's binding. Could be the pedal, the cable, or the TB. Disconnect them and you should be able to see which.
KENNY |
Feb 20 2013, 08:19 AM
Member Group: Members Posts: 142 Joined: 5-February 03 From: Orlando fl. Member No.: 243 Region Association: None |
How do you get it back into the correct position. With the throttle pedal or by hand at the throttle body? Are you sure it's not fouled up with the clutch cable just inside the front of the tunnel ? Easy to do. (IMG:style_emoticons/default/agree.gif) |
KaptKaos |
Feb 20 2013, 08:29 AM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I replaced a clutch cable and it got wrapped around a brake line. Check the tunnel. Make sure its not tangled up.
lennyhope |
Feb 20 2013, 03:33 PM
I just passed the new cable through and it popped up near the cluster and attached it...Didnt see anything to get in th eway...
Feb 20 2013, 04:39 PM
It's been known to happen, even that way. Double-check.
Disconnect each end of the cable so you can find what exactly is sticking. The pedal, the cable itself, the throttle plate, or ??? --DD |
RoadGlue |
Feb 20 2013, 04:47 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Yep! Sounds like it's getting caught on the clutch cable. All of us have done it (some of us... um, me, more than once!). A small round mirror (like for a dentist) on a hinge works wonders for seeing what you've done. HF has 'em for pennies. (IMG:style_emoticons/default/wink.gif)
lennyhope |
Feb 21 2013, 02:27 PM
Yep! Sounds like it's getting caught on the clutch cable. All of us have done it (some of us... um, me, more than once!). A small round mirror (like for a dentist) on a hinge works wonders for seeing what you've done. HF has 'em for pennies. (IMG:style_emoticons/default/wink.gif) Thanks. Will let you know what I find... (IMG:style_emoticons/default/beerchug.gif) |
AZ914 |
Feb 21 2013, 02:49 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Yep! Sounds like it's getting caught on the clutch cable. All of us have done it (some of us... um, me, more than once!). A small round mirror (like for a dentist) on a hinge works wonders for seeing what you've done. HF has 'em for pennies. (IMG:style_emoticons/default/wink.gif) Been there... done that.. I think more people have this problem than not. (IMG:style_emoticons/default/biggrin.gif) |
stugray |
Feb 21 2013, 05:57 PM
I had a similar problem when I first installed carbs. New cable, not tangling with clutch cable, and it would still bind and not let the carbs close. I tried extra springs to pull the cable towards the engine bay, but it made it worse.
Then I removed all extra springs using only the ones on the carbs, and the cable moved smotth as silk. If you put too much tension on the cable, it will bind. Stu |
Lo-Fi Version | Time is now: 25th May 2024 - 03:19 AM |
