transmission mounts, Best place to get them for street only car |
rgolia |
Feb 20 2013, 10:32 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
Need to replace the originals that are still in service...and suggestions?
ConeDodger |
Feb 20 2013, 10:36 AM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
For the street, replace stock with stock. Available at many sources like Pelican, the dealership, etc... Even if you are an autocrosser, the solid mounts available are too annoying to deal with on the street. I think I have a set of solid mounts in my stash that I put on and took back off due to the vibration and noise.
I have not experienced the WEVO mounts so I am not speaking of these... |
'73-914kid |
Feb 20 2013, 11:56 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
I've had pretty good luck with 911 sports on the transmission ears. They bolt right on with the addition of a big washer, and make things a little more stiff than stock, but not all that much. Definetely helps tighten things up at the back of the drivetrain.
LotusJoe |
Feb 20 2013, 12:31 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I've had pretty good luck with 911 sports on the transmission ears. They bolt right on with the addition of a big washer, and make things a little more stiff than stock, but not all that much. Definetely helps tighten things up at the back of the drivetrain. (IMG:style_emoticons/default/agree.gif) 911 mounts work just fine. |
DRPHIL914 |
Feb 20 2013, 01:25 PM
I've had pretty good luck with 911 sports on the transmission ears. They bolt right on with the addition of a big washer, and make things a little more stiff than stock, but not all that much. Definetely helps tighten things up at the back of the drivetrain. (IMG:style_emoticons/default/agree.gif) did the same a year ago, i had no idea how bad my original ones were. |
chads74 |
Feb 20 2013, 03:06 PM
Member Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States |
Where would you recommend gettting the 911 mounts and maybe a part # for good measure?
scott_in_nh |
Feb 20 2013, 03:07 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I've had pretty good luck with 911 sports on the transmission ears. They bolt right on with the addition of a big washer, and make things a little more stiff than stock, but not all that much. Definetely helps tighten things up at the back of the drivetrain. (IMG:style_emoticons/default/agree.gif) Same here. |
'73-914kid |
Feb 20 2013, 04:20 PM
Any of these will do from Pelican Pelican parts
ThePaintedMan |
Feb 20 2013, 04:28 PM
Yeah, having just installed the WEVO mounts T.C. sold me, it is going to introduce a ton of vibration that someone with a daily driver probably won't want.
rgolia |
Feb 20 2013, 04:56 PM
How about these? Would they be closer to the stock ride than the 911 sport ones?
http://www.automotion.com/transmission-mou...-1970-1976.html |
DRPHIL914 |
Feb 20 2013, 06:34 PM
How about these? Would they be closer to the stock ride than the 911 sport ones? http://www.automotion.com/transmission-mou...-1970-1976.html Did not.know those existed! Cant beat the price, i would try them Dont know how firm they are. I will tell you that i like the 911 mounts.i have not noticed much vibration. |
914Sixer |
Feb 20 2013, 06:43 PM
Those mounts are the ones made by URO. The good Dr 914 has now introduced his version which is a copy of the factory mounts at about the same price.
Drums66 |
Feb 20 2013, 08:06 PM
.....My opinion is, for a street ride, 1 wouldn't want the mounts too
rigid(potholes,speed bumps,surprise-dips & so forth) (IMG:style_emoticons/default/idea.gif) so close to stock as possible! (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
euro911 |
Feb 20 2013, 08:22 PM
UROs are Chinese repros, No?
I went with 911 mounts. |
Dr Evil |
Feb 20 2013, 09:02 PM
I only use the 911 sport mounts as they are cheaper and BETTER than the stock ones that are weaker and rupture.
mittelmotor |
Feb 20 2013, 10:15 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
I went the 911 Sport route with my car too. You have to oval out the holes on the mounts a little to match the holes in the crossmember, but no biggie.
rgolia |
Feb 22 2013, 05:00 PM
Thanks for all the input...911 sport mounts it is..... (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 07:11 PM |
