rgolia
Feb 20 2013, 10:32 AM
Need to replace the originals that are still in service...and suggestions?
ConeDodger
Feb 20 2013, 10:36 AM
For the street, replace stock with stock. Available at many sources like Pelican, the dealership, etc... Even if you are an autocrosser, the solid mounts available are too annoying to deal with on the street. I think I have a set of solid mounts in my stash that I put on and took back off due to the vibration and noise.
I have not experienced the WEVO mounts so I am not speaking of these...
'73-914kid
Feb 20 2013, 11:56 AM
I've had pretty good luck with 911 sports on the transmission ears. They bolt right on with the addition of a big washer, and make things a little more stiff than stock, but not all that much. Definetely helps tighten things up at the back of the drivetrain.
LotusJoe
Feb 20 2013, 12:31 PM
QUOTE('73-914kid @ Feb 20 2013, 09:56 AM)
911 mounts work just fine.
DRPHIL914
Feb 20 2013, 01:25 PM
QUOTE('73-914kid @ Feb 20 2013, 12:56 PM)
did the same a year ago, i had no idea how bad my original ones were.
chads74
Feb 20 2013, 03:06 PM
Where would you recommend gettting the 911 mounts and maybe a part # for good measure?
scott_in_nh
Feb 20 2013, 03:07 PM
Same here.
'73-914kid
Feb 20 2013, 04:20 PM
Any of these will do from Pelican
Pelican parts
ThePaintedMan
Feb 20 2013, 04:28 PM
Yeah, having just installed the WEVO mounts T.C. sold me, it is going to introduce a ton of vibration that someone with a daily driver probably won't want.
rgolia
Feb 20 2013, 04:56 PM
How about these? Would they be closer to the stock ride than the 911 sport ones?
http://www.automotion.com/transmission-mou...-1970-1976.html
DRPHIL914
Feb 20 2013, 06:34 PM
QUOTE(rgolia @ Feb 20 2013, 05:56 PM)
http://www.automotion.com/transmission-mou...-1970-1976.htmlDid not.know those existed! Cant beat the price, i would try them
Dont know how firm they are. I will tell you that i like the 911 mounts.i have not noticed much vibration.
914Sixer
Feb 20 2013, 06:43 PM
Those mounts are the ones made by URO. The good Dr 914 has now introduced his version which is a copy of the factory mounts at about the same price.
Drums66
Feb 20 2013, 08:06 PM
.....My opinion is, for a street ride, 1 wouldn't want the mounts too
rigid(potholes,speed bumps,surprise-dips & so forth)
so close to stock as possible!
euro911
Feb 20 2013, 08:22 PM
UROs are Chinese repros, No?
I went with 911 mounts.
Dr Evil
Feb 20 2013, 09:02 PM
I only use the 911 sport mounts as they are cheaper and BETTER than the stock ones that are weaker and rupture.
mittelmotor
Feb 20 2013, 10:15 PM
I went the 911 Sport route with my car too. You have to oval out the holes on the mounts a little to match the holes in the crossmember, but no biggie.
rgolia
Feb 22 2013, 05:00 PM
Thanks for all the input...911 sport mounts it is.....
