Circlip Removal....., Don't have the right tool..... |
jim_hoyland |
Feb 24 2013, 12:29 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have the glove box lock out for re-keying. The back of the lock has a circlip that retains the tumbler into the lock body.
Any tricks to removing this circlip, I don' have snap ring pliers. Is a trip to HF gonna be required ? (IMG:http://www.914world.com/bbs2/uploads/post-180-1172096579.jpg) |
Mike Bellis |
Feb 24 2013, 12:53 PM
Is that not your picture? Sure looks like the right tool.
If not, go get the correct tool. Go to Sears and get a Craftsman. The HF tools are not hard enough to last long. The tips wear out. |
walterolin |
Feb 24 2013, 12:58 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Here's a thread Jeffs9146 referred me to a while back:
http://www.practicalmachinist.com/vb/gener...-prefer-207392/ The cheap sets are made out of crappy metal, and don't hold up. The good ones cost a bunch. |
stugray |
Feb 24 2013, 03:08 PM
All FLAPS have the cheaper tool with the different jaws & tips (even Walmart)
They are cheap and dont hold up well, but will gt you through this snad the next few times you need circlip pliers. Stu |
McMark |
Feb 24 2013, 04:14 PM
Sometimes you can get lucky by inserting a flathead screwdriver and twisting.
jim_hoyland |
Feb 24 2013, 04:31 PM
Sometimes you can get lucky by inserting a flathead screwdriver and twisting. (IMG:style_emoticons/default/smile.gif) That did the trick (IMG:style_emoticons/default/smile.gif) Gonna stop by Walmart next week and pick up a pair; probably on use them once a year... |
aircooledtechguy |
Feb 25 2013, 07:32 PM
Sometimes you can get lucky by inserting a flathead screwdriver and twisting. (IMG:style_emoticons/default/smile.gif) That did the trick (IMG:style_emoticons/default/smile.gif) Gonna stop by Walmart next week and pick up a pair; probably on use them once a year... Getting it off is the easy part. That same screw driver will piss you off trying to get it back together. . . Get the right tool. Sears is your friend. . . |
914Sixer |
Feb 25 2013, 08:59 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Jim,
You have the right tool. Remove the thumb screw and reverse the sides. It should work in the opposite direction. It will work in either direction. |
Lo-Fi Version | Time is now: 21st May 2024 - 08:50 AM |
