fog lights or brights |
last337 |
Feb 25 2013, 12:53 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
Silly question, but where is the switch for the fog lights? I have the pull switch for brights and when I pull it the indicator lights up but I get nothing different from the headlamps. Shouldnt that activate the brights? I dont know how to check for those and cant find anything about it in Haynes.
I have fog lights installed below the headlights as well but dont know where the switch for those would be either. There are currently no lights in the fog lights and they take a huge light that I cant find at FLAPS. Any help is appreciated (IMG:style_emoticons/default/biggrin.gif) |
JawjaPorsche |
Feb 25 2013, 01:38 PM
Don't you have a green fog pull switch on your dash next to your headlight switch? Your fog lights only work on headlight dim not bright. Your fog light bulbs could be burned out too.
Pelican sells the bulbs http://www.pelicanparts.com/cgi-bin/smart/...74%29%2C%20Each |
ArtechnikA |
Feb 25 2013, 01:50 PM
Silly question, but where is the switch for the fog lights? I have the pull switch for brights and when I pull it the indicator lights up but I get nothing different from the headlamps. There is no 'pull switch on the dash' for brights... There is a single switch for parking lights (first detent) and _headlights_ (second detent). You switch between highbeams and low beams by pulling back on the turn signal stalk. It is not a push/pull like lots of modern cars. You pull back once to change from highs to lows, pull back again to switch the other way. The headlight indicator does not light up. Pretty sure the dash switch you're talking about _is_ the fog light switch. Fog lights light up only with the low beams. all this - including the bulb types - is in the owner's manual... (If you have aftermarket fog lights - you're on your own...) |
underdog |
Feb 25 2013, 02:04 PM
Member Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
what year is your 914?
Wegeng_Haus |
Feb 25 2013, 02:55 PM
Newbie Group: Members Posts: 38 Joined: 10-December 11 From: Champaign Illinois Member No.: 13,881 Region Association: Upper MidWest |
If your car was born without fog lights and you added them, you may not have a foglight switch. There is a cut-out for it, on the subframe of the dash and it is easy to locate, from behind. There are cut outs for three switches, left of the column. If you only have two, you need to get a switch, make a hole and install it.
Wegeng_Haus |
Feb 25 2013, 03:26 PM
Sorry, there may actually be four punch-outs, on the dash, left of the column.
last337 |
Feb 25 2013, 05:50 PM
Cool I figured it out and its all working now. All I need now is some new bulbs for fog lights. Thanks for help!
914Sixer |
Feb 25 2013, 07:14 PM
Bulbs are special, not on most parts shelfs. Pelican Parts has them for $8.
steuspeed |
Feb 25 2013, 07:44 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Upgrade your lights with the Fog Flash kit from JWest. I drive til dusk using just my fog lights. It's so nice not having the pop-ups up. Plus you can flash fellow teeners when you see them coming down the road.
(IMG:style_emoticons/default/driving.gif) http://www.jwesteng.com/porsche/914/fog.htm |
underdog |
Feb 26 2013, 11:29 AM
we answered your question why didn't you answer mine?
Lo-Fi Version | Time is now: 17th May 2024 - 08:25 PM |
