Trans Output flange, Galling |
Black22 |
Feb 25 2013, 10:01 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
ThePaintedMan |
Feb 25 2013, 10:04 PM
Bad (or wrong type) of CVs? Lack of lubrication meaning the cage and balls were locking in place against the flange, causing rubbing?
Mike Bellis |
Feb 25 2013, 10:31 PM
I've seen that damage after a CV failure. Should be OK to use.
mrbubblehead |
Feb 25 2013, 10:35 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
It looks like the star has been banging into it. was the cir clip on it?
Black22 |
Feb 25 2013, 11:42 PM
Bad (or wrong type) of CVs? Lack of lubrication meaning the cage and balls were locking in place against the flange, causing rubbing? The old ones were worn but all still intact. Full of lube. I've seen that damage after a CV failure. Should be OK to use. Could have happened with the PO. I am using them now, but always wondered what could've caused it. It looks like the star has been banging into it. was the cir clip on it? Cir-clips were there, but once removed I couldn't get the cv's off due to the marred splines on the shaft. Got replacement shafts from Jeffs9146!!! Thanks again Jeff! (IMG:style_emoticons/default/first.gif) Just wondering if there was any way to avoid this or if it was normal wear. One cv did have a lot of extension compared to the others. I thought it was just worn out, but both flanges had similar signs of galling. |
mrbubblehead |
Feb 25 2013, 11:50 PM
I have dozens of flanges here that have those same marks. I would not be afraid to use them. unless they were super bad like metal was actually gouged out.
ThePaintedMan |
Feb 26 2013, 07:55 AM
The flange seems okay, but I would ensure the CVs themselves aren't doing something weird. Again, maybe someone tried to install a different type of CV on the car that has the same splines but has a further range of motion than it should. I'm not sure thats possible, but while you have them out you could cross-reference between them to make sure they're the same. |
charliew |
Feb 26 2013, 10:54 AM
More than likey this was from another phase in the cars life unless you found metal in the cavity.
McMark |
Feb 26 2013, 11:01 AM
When CVs wear, they can hyper extend in either direction. This is wear caused by running a dead CV for a long period of time. It's good to use.
Check your CV health by laying on the ground behind your car, reach up and grab the axle and use a sharp thrust to try and bang and axle against the transmission or against the wheel hub. If you hear it tap against something in either direction, your CVs are getting old. The easier (less force) it take to make this happen, the more worn out the CVs are. |
Black22 |
Feb 26 2013, 11:32 AM
When CVs wear, they can hyper extend in either direction. This is wear caused by running a dead CV for a long period of time. It's good to use. Check your CV health by laying on the ground behind your car, reach up and grab the axle and use a sharp thrust to try and bang and axle against the transmission or against the wheel hub. If you hear it tap against something in either direction, your CVs are getting old. The easier (less force) it take to make this happen, the more worn out the CVs are. Good info guys, thanks for your help. McMark, that is a good test. I'll have to try that in a few thousand miles. I have PMB's modified CV's on there now with only 650 miles on them. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:49 PM |
