Retrofitting Air Conditioning |
ScoopLV |
Mar 1 2013, 03:07 AM
Senior Member Group: Members Posts: 545 Joined: 7-September 12 From: Las Vegas Member No.: 14,897 Region Association: Southwest Region |
I searched the old posts. 1) Ed Gilmore's system is still "in development" on his web page. It's been in development for almost eight years now. I'm not holding my breath. 2) There appears to be exactly one "here's what you need" kit available, from a company in Georgia. Hefty price tag -- $2,700 to $3,100 for a system. That seems AWFULLY high to me. Has anyone installed this kit? Any comments about it? 3) There is, of course, the "inverter and small home AC" option. But that isn't for me. No thanks. Are there other options? The old posts mention cobbled-together systems that resulted in blown belts, bent bolts, and major oil leaks. I don't want any of that. |
bulitt |
Mar 1 2013, 05:31 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
pcar916 |
Mar 1 2013, 12:07 PM
stugray |
Mar 1 2013, 01:28 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/blog.ivman.com-10819-1362166115.1.jpg)
Put the AC in the front trunk and the generator in the rear. |
DBCooper |
Mar 1 2013, 02:53 PM
Nice LED tail lights too. Sleek.
ScoopLV |
Mar 1 2013, 03:26 PM
So, I can pretty-much assume that nobody has purchased the $3,000 kit from you-know-who.
Like I said in my original post, $3,000 for an air conditioning kit seems way out of line to me. A Sanden compressor costs around $200. A condenser also costs around $200. The hardware and lines will cost around $100. So where is the other $2,500 going? |
monkeyboy |
Mar 1 2013, 05:31 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Development for a highly limited market. Looks like a proprietary set of vents too.
You could probably do something close with a vintage air kit, and a pully kit for the old a/c systems |
Joe Owensby |
Mar 1 2013, 06:10 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
So, I can pretty-much assume that nobody has purchased the $3,000 kit from you-know-who. Like I said in my original post, $3,000 for an air conditioning kit seems way out of line to me. A Sanden compressor costs around $200. A condenser also costs around $200. The hardware and lines will cost around $100. So where is the other $2,500 going? You left out a few things. Compressor mount, belt, pulley, evaparator, housing for compressor and fan, relay and wires, etc. Lots of stuff. Plus I would imagine you know who would want to make a few bucks on all this.. Maybe you could provide the kits a lot cheaper. That said, i think i have a post from years ago describing a system i put in mine. Southern ROds sells the parts you need except the pulley and compressor mount. They have a small evaporator that fits nicely. You have to make compressor mount, condensor mount and shroud, get lines made, etc. I think i ended up spending 800 or so for parts. I had an old mount. JoeO |
3d914 |
Mar 1 2013, 06:13 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
bandjoey |
Mar 1 2013, 09:12 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Oldairproducts.com sells hot rod a/c kits that look like original units.
http://www.oldairproducts.com/catalog/unde...age-p-4487.html Also. Has anyone looked into using an electrical compressor? Boats and RV and Euro cars use them all day long. |
dlee6204 |
Mar 1 2013, 10:20 PM
$3K is indeed pricey for a kit however its not completely absurd. When I first put together my system, I spent maybe $500 but I already had the evaporator unit and the condenser and I did all my own fabrication to mount the compressor and made my own lines. To build a system from scratch out of all new parts would easily be more than $1K in parts alone. This of course doesn't take into account the work necessary to put a system together and then install it.
I've thought about putting together a complete kit however its quite a bit of work and there's quite a few variables to consider. For instance not everyone wants to cut a hole in their front trunk for a condenser or cut their engine shelf for the compressor. IIRC, with the AA kit you have to do both. As of right now there's not one best way to add A/C to a 914. So there's not much out there for a "kit" but my thread can help you decide on some of the different variables when someone puts together their own system. If cost is a big factor, the easiest and cheapest way to add A/C will be to buy a used 914 A/C system and update some of the key components. |
dlee6204 |
Mar 1 2013, 10:34 PM
The electric compressor is not really a good idea. Electric compressors on hybrid vehicles run at a much high voltage so not only would you need the compressor, but you would also need a custom inverter setup and a big ass alternator. Even if you could find a 12V electric compressor, you're still going to need a big alternator. |
ScoopLV |
Mar 2 2013, 02:25 AM
Oldairproducts.com sells hot rod a/c kits that look like original units. http://www.oldairproducts.com/catalog/unde...age-p-4487.html $400 plus incidentals sounds a whole lot better to me than $2.7K to 3.1K plus incidentals. It's clear to me that this will not be "this years" project. I don't even have the engine back in yet. It just sucks because I only have three months until it gets way too damned hot to drive a car with no AC. And with the engine already out of the car, I was hoping there was a tried-and-true solution for those of us who live in the south and southwest. If you're wondering, yes, I HATE Las Vegas. PS -- 3d914, this is a 1974 914 1.8, basically bone stock. |
bandjoey |
Mar 2 2013, 09:25 AM
I googled Hot Rod Air Conditioning and came up with multiple companies. Here's an aritcle from Hot Rod Magazine:
http://www.hotrod.com/howto/hrdp_0706_air_...ng/viewall.html I see kits complete out there for $800-$1000. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:09 AM |
