D-jet FI and air box: Is this a problem?, Two questions: Is this right? And how to adjust air/fuel mixture? |
TheCabinetmaker |
Mar 12 2013, 03:41 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
There are two of the over center clamps on the bottom of the air box. one in front, and one in the rear. They clamp the entire box to a bracket that bolts to the intake runners. Pop those two clamps loose and remove the whole box. The one in front is easy to get to, They one is the back has to be done by "feel". Then remove the rubber seal from the throttle body and install it on the air box. Then set the box back on the throttle body centering the rubber on the TB. When everything sets properly, pop the two clamps back on. While you have the air filter box off, you can see the bracket on the intake runners. It should run parallel with the centerline of the engine case. Looks like the bracket might be crooked causeing the misalignment at the TB.
tumamilhem |
Mar 12 2013, 04:24 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
I did that already. Didn't make a difference. :/
Lo-Fi Version | Time is now: 28th May 2024 - 08:03 PM |
