NEW HERE:) |
NEW HERE:) |
Tyler_TheMan_93 |
Mar 2 2013, 02:37 PM
Newbie Group: Members Posts: 16 Joined: 22-December 12 From: Indianapolis, IN Member No.: 15,277 Region Association: None |
ok so i just bought a 1976 porsche 914 from my girlfriends dad and it hasnt been started since 1986. he said that he thinks the cylinder wall was messed up something. but anyway its been sitting since 86' and i would like to know what to do/check before i try to start it. i am new to the porsche world so i look forward to talking with all of you.
here are some pics: the interior is amazingly clean |
tscrihfield |
Mar 2 2013, 02:42 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Looks nice! Did he happen to say why he thinks that? What engine size? |
tumamilhem |
Mar 2 2013, 02:47 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
Very nice! Welcome to 914 World! I hope you enjoy your car as much as we do! I was very excited when I got my first 914 which was a real junk car. Now I'm on my third one in 10 years. (IMG:style_emoticons/default/smile.gif)
FYI, my first one had an A/C unit in it. The A/C unit will reduce power in your car significantly. There's not much horsepower to begin with, so it does make a difference. They are a real pain in the ass to install and remove, so depending on where you are, if you don't really need it and want to sell it, I know JRust is looking for one for his V8 conversion. I would have happily given him mine if I still had it. They were not factory, but a dealer option. Because of the reduction in HP, they were not too common except in climates like mine (FL). But they are few and far between, so if you want to sell it, JRust will probably be interested in it. (IMG:style_emoticons/default/smile.gif) Welcome to the club! |
Spoke |
Mar 2 2013, 02:48 PM
Nice ride. To get it going, at least check the oil level, perhaps change if necessary. Once you get it running, definitely change the oil. Check the condition of the gas. You will have to siphon some gas out of the tank to take a look at it. If varnished, you have to remove all the gas and clean the tank, maybe even redo all the hoses. Overall inspection of the wiring and hoses in the engine compartment. Check all the hoses in the engine compartment for dry rot. Check/change the spark plugs. Check/change the points. |
Tyler_TheMan_93 |
Mar 2 2013, 02:55 PM
(IMG:style_emoticons/default/welcome.png) Looks nice! Did he happen to say why he thinks that? What engine size? thanks! its a 2.0 and he said that something went wrong with the piston and it hit the cylinder wall but then he said he fixed it. but then he said the last time he drove it he heard like a knock or tick when he got home. shut it off and hasnt been started since. i pretty much know nothing about these engines.lol |
abnrdo |
Mar 2 2013, 02:59 PM
Member Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
Nice!! (IMG:style_emoticons/default/welcome.png)
Tyler_TheMan_93 |
Mar 2 2013, 03:20 PM
Drums66 |
Mar 2 2013, 03:36 PM
......Cool Man!.....Welcome!!
(IMG:style_emoticons/default/bye1.gif) |
jim_hoyland |
Mar 2 2013, 05:55 PM
Get that VIN ? Group: Members Posts: 9,287 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
(IMG:style_emoticons/default/welcome.png) The rubber brake lines may have swelled internally. Can't tell from the inside, a common problem when these cars sit. You should consider replacing them.
JawjaPorsche |
Mar 2 2013, 06:29 PM
Welcome the madness! You have come to the right place!
Mar 2 2013, 06:39 PM
Get a compression tester from the local auto parts store. Get one that uses a hose and screws into the plug hole. Follow the directions and test each cylinder with the throttle body pinned wide open and the fuel pump unplugged (or the relay unplugged) Get those numbers back to everyone here and you will get an answer on what to do next. You will learn alot here, and may people have been in your shoes. You will be an expert in less than a year...and we all welcome you. rich |
Tyler_TheMan_93 |
Mar 2 2013, 06:52 PM
(IMG:style_emoticons/default/welcome.png) The rubber brake lines may have swelled internally. Can't tell from the inside, a common problem when these cars sit. You should consider replacing them. wow, awesome info thanks man, i will definitely look at that |
Tyler_TheMan_93 |
Mar 2 2013, 06:53 PM
(IMG:style_emoticons/default/welcome.png) Get a compression tester from the local auto parts store. Get one that uses a hose and screws into the plug hole. Follow the directions and test each cylinder with the throttle body pinned wide open and the fuel pump unplugged (or the relay unplugged) Get those numbers back to everyone here and you will get an answer on what to do next. You will learn alot here, and may people have been in your shoes. You will be an expert in less than a year...and we all welcome you. rich wow thank you man. ill get right on that compression test and post it up here (IMG:style_emoticons/default/aktion035.gif) |
Mar 2 2013, 07:08 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Replace all the rubber fuel lines, including those under the gas tank. High-pressure fuel leaking (spraying) onto a hot engine is a recipe for fire. FIRE BAD!!!
Replace all the fluids; oil and gear oil, brake fluid, and very likely the fuel as well. (Does the fuel smell like fuel? If so, it may be fine.) --DD |
Tyler_TheMan_93 |
Mar 2 2013, 07:15 PM
Replace all the rubber fuel lines, including those under the gas tank. High-pressure fuel leaking (spraying) onto a hot engine is a recipe for fire. FIRE BAD!!! Replace all the fluids; oil and gear oil, brake fluid, and very likely the fuel as well. (Does the fuel smell like fuel? If so, it may be fine.) --DD thanks, ill be sure to do that as well. i havnt smelled the fuell yet but ill probaly get rid of it anyway |
montoya 73 2.0 |
Mar 2 2013, 09:47 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
If your just trying to start it then worry about the fuel, fuel lines and your basic tuneup stuff. If you have basic mechanical skills your half way there. Im still learning as well and i have been into aircooled vw's since 1984 and 914's since 1988. Good luck and (IMG:style_emoticons/default/welcome.png)
Socalandy |
Mar 2 2013, 10:01 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
type47 |
Mar 3 2013, 06:21 AM
reserve Apr 20th for a trip to Hershey PA to meet alot of other 914er's (maybe you'll decide to sell your new prize after the exposure (IMG:style_emoticons/default/biggrin.gif) ) and buy alot of old rusty parts to fill up your garage 'cause "you'll need them someday..."
JawjaPorsche |
Mar 3 2013, 07:45 AM
Wanted: Girlfriend who has a father who wants to sell me a nice Porsche 914. Send picture of 914.
Why can't I be that lucky?! |
rick 918-S |
Mar 3 2013, 07:50 AM
Hey nice rack! -Celette Group: Members Posts: 20,456 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Lots of good info so far but let me add this. Any car that sat since 1986 will have stale gas. Do not try to start the car with stale gas. Drain it.
Take a flash light and look into the gas tank and check for rust. Rust will eventually cause some real issues with the filter and even the injectors. There is a way to de-rust the tank with Arm & Hammer washing soda and a battery charger. Google it. It works, I've done it. Change all the fuel lines. The rubber set will have varnished fuel deposits and decomposing rubber that new fuel will loosen and wash into the filter and eventually the injection. Order the stainless line set for the tunnel from Chris Foley at Tangerine Racing. The plastic lines will also likely have started to decompose and crack. There have been many horror stories of car fires from failed lines. I have a car here that was a Cali car the burned from a split fuel line. Check the member vendor section. Change the oil. Don't skip this. Change the oil and use some type of break in oil. Look for Brad Penn oil in your area. The replacement oil will actually help in cleaning out the condensation that forms from sitting. As Rich stated run a compression check and post the results. It sounds like the car may have had a loose valve seat that caused damage to a cylinder. If the ticking came back it is likely the seat went un noticed during the cylinder repair. You'll know when you check the compression. In review: Clean and repair the fuel system, change the oil, check the compression, report back. Wait to start fire it up until you know what the compression results are. If you have a loose valve seat you will want to repair it before firing it up and destroying the engine. Lots to do to wake up a sleeping car. But that's the basics for the engine. The brakes are the next step. (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 13th May 2024 - 07:54 PM |
