oil pump for 2056 |
oil pump for 2056 |
jmargush |
Mar 4 2013, 06:43 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
What are the recommendations for an improved oil pump for a 2056?
I have heard that Melling has a cast iron pump, and Schadek also supposedly has a good pump. What are the pros and cons? Any others pumps that are good improvements over the stock pump? |
Cap'n Krusty |
Mar 4 2013, 07:44 PM
And what's wrong with the stock pump? Works fine with 2 liters. Why wouldn't it work fine with 2.1 liters, more or less? If it ain't broke, don't fix it ...............
The Cap'n |
VaccaRabite |
Mar 4 2013, 08:36 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
If your existing pump is in good shape, use it. If its not in good shape, then worry about the others.
You don't need a bigger pump unless you are doing a larger oil system (like a front mount cooler or the like.) Zach |
jmargush |
Mar 4 2013, 08:56 PM
Just remembered reading some about stock type 4 pumps weren't as robust as Type 1.
Maybe that is in relation to higher capacity oil systems. |
finchmunoz |
Mar 5 2013, 09:55 AM
Newbie Group: Members Posts: 34 Joined: 3-July 11 From: Manila, Philippines Member No.: 13,272 Region Association: None |
what is the biggest "stock" pump for a Type 4 anyway? how many mm?
Lo-Fi Version | Time is now: 17th May 2024 - 05:25 PM |
