jmargush
Mar 4 2013, 06:43 PM
What are the recommendations for an improved oil pump for a 2056?
I have heard that Melling has a cast iron pump, and Schadek also supposedly has a good pump.
What are the pros and cons?
Any others pumps that are good improvements over the stock pump?
Cap'n Krusty
Mar 4 2013, 07:44 PM
And what's wrong with the stock pump? Works fine with 2 liters. Why wouldn't it work fine with 2.1 liters, more or less? If it ain't broke, don't fix it ...............
The Cap'n
VaccaRabite
Mar 4 2013, 08:36 PM
If your existing pump is in good shape, use it. If its not in good shape, then worry about the others.
You don't need a bigger pump unless you are doing a larger oil system (like a front mount cooler or the like.)
Zach
jmargush
Mar 4 2013, 08:56 PM
Just remembered reading some about stock type 4 pumps weren't as robust as Type 1.
Maybe that is in relation to higher capacity oil systems.
finchmunoz
Mar 5 2013, 09:55 AM
what is the biggest "stock" pump for a Type 4 anyway? how many mm?
