too lean? |
too lean? |
last337 |
Mar 8 2013, 06:48 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
I thought I had my carbs dialed in perfectly but when starting on a slightly cold day I have a heck of a time getting it started plus the carbs pop for some time until the engine warms. Should I try fattening up each barrel a bit? I'm asking BC it runs so good at operating temp which is where I adjusted it.
brant |
Mar 8 2013, 09:32 AM
I thought I had my carbs dialed in perfectly but when starting on a slightly cold day I have a heck of a time getting it started plus the carbs pop for some time until the engine warms. Should I try fattening up each barrel a bit? I'm asking BC it runs so good at operating temp which is where I adjusted it. you need to borrow a wide band AF meter to answer your question. its all guess work otherwise.... they could be fine in at one rpm range and off in another. |
'73-914kid |
Mar 8 2013, 09:41 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Webers are notoriously cold blooded on our engines.. Poor running when cold is usually just a side effect of having them without a choke..
If it runs great when warm, then I wouldn't worry about how it runs when warming up... |
last337 |
Mar 8 2013, 10:16 AM
Its more of just the difficulty in starting. I may try to fatten up each just a hair to see if it improves starting then go from there. I know my neighbors were hating me this morning (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 13th May 2024 - 11:13 PM |
