QUOTE(last337 @ Mar 8 2013, 05:48 AM)
I thought I had my carbs dialed in perfectly but when starting on a slightly cold day I have a heck of a time getting it started plus the carbs pop for some time until the engine warms. Should I try fattening up each barrel a bit? I'm asking BC it runs so good at operating temp which is where I adjusted it.
you need to borrow a wide band AF meter to answer your question.
its all guess work otherwise....
they could be fine in at one rpm range and off in another.
