Security lug nut removal, No key no tool |
motorvated |
Mar 10 2013, 02:19 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Any way other than cutting it off?
gms |
Mar 10 2013, 02:23 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
jeeperjohn56 |
Mar 10 2013, 02:56 PM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
I have used a deep size socket that will go over the key end and pounded it on with a hammer and used a inpack gun to take it off. John
Mike Bellis |
Mar 10 2013, 03:38 PM
I have used a deep size socket that will go over the key end and pounded it on with a hammer and used a inpack gun to take it off. John (IMG:style_emoticons/default/agree.gif) You could also take it to your local tire shops. They have ways of removing these things... |
Mike Bellis |
442nd914s |
Mar 10 2013, 03:43 PM
Member Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None |
Harbor Frieght sells a security bit set with every security bit kniwn to man for $20. Just a thought. Also try a good set of vise grip pliers around the screw head.
bulitt |
Mar 10 2013, 04:22 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Chisel and a hammer. Tip of chisel on outer edge and beat it counter clockwise
toolguy |
Mar 10 2013, 04:51 PM
I agree with pound on a socket. . done it before. . you will probably destroy the socket but it's the fastest, easiest way.
I used a thick wall impact socket. . I found thin wall cheap sockets will usually split when you pound them on |
Cupomeat |
Mar 10 2013, 04:54 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Just take it to a shop, they have all the keys and you won't screw around with hurting it.
euro911 |
Mar 10 2013, 06:13 PM
These are nice, but this set only goes up to 14mm. You can check to see if they make them for larger bolts (IMG:style_emoticons/default/confused24.gif)
racerbvd |
Mar 10 2013, 06:21 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Sears also sells a reverse threaded socket for removing stripped & odd shaped bolts, I used one to remove a broken locking lug on the Carrera..
somd914 |
Mar 10 2013, 08:18 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I've been down this road - tried the local shops, all had destructive methods and wanted $20+ plus drop the car off or wait - take a book... Bought a cheap $6 socket, pounded it on, lug came right off, was able to remove the lug from the socket which survived.
After this I tossed all my security lugs - they are certainly easily defeated and were a hassle with wheel removal. |
balljoint |
Mar 10 2013, 08:29 PM
Pound on a socket. Impact wrench to remove. BTDT x 2 due to cracked security lug nuts. The other 2 went in the trash. Sockets were fine. |
Jon H. |
Mar 12 2013, 02:01 PM
Member Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
I agree with the hammer and chisel method. I've had to do I this way several times and it worked fine.
get off my lawn |
Mar 12 2013, 05:47 PM
Member Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None |
I have used a deep size socket that will go over the key end and pounded it on with a hammer and used a inpack gun to take it off. John This, pound a socket onto it and use a breaker bar. It'll prolly trash the socket but should work. I've done it a few times over the years. |
FourBlades |
Mar 12 2013, 07:14 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Local Porsche dealer took mine off in 2 minutes for free using a master set. Of course, I have spent $$,$$$ on maintenance for my 911 with them. I gave them all 4 keyed ones in exchange for non-keyed and they were happy. John |
PlaysWithCars |
Mar 12 2013, 10:44 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Another vote for a cheap socket and a BFH.
carr914 |
Mar 13 2013, 05:39 AM
Racer from Birth Group: Members Posts: 118,580 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Local Porsche dealer took mine off in 2 minutes for free using a master set. Of course, I have spent $$,$$$ on maintenance for my 911 with them. I gave them all 4 keyed ones in exchange for non-keyed and they were happy. John (IMG:style_emoticons/default/agree.gif) At the Dealership I worked at we did this a lot, but go to the Parts Dept, not the Service Drive. After it's done Tip the Dude that did it! Also Sears sells a kit to remove any Security Lug When Completed throw the Security Lugs away - thieves have the Tools and if they want your wheels, will take them! |
motorvated |
Mar 13 2013, 08:29 PM
First socket I tried fit right on and lug came right off. You guys are great!
Lo-Fi Version | Time is now: 13th May 2024 - 03:22 PM |
