Help adding rear negative camber |
sixaddict |
Mar 10 2013, 08:09 PM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Just corded another rear tire on outboard edge due to in adequate negative camber...Unable to get more than 1.8 - 1.9 ...All shims out.....
How can it be done without chopping up the car. Looking for at least 2.5 Thanks Terry |
Krieger |
Mar 11 2013, 09:36 AM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I spoke to Chris at tangerine racing about this once. He sells his own trailing arm brackets that he might be able to build with a little more camber.
Woody |
Mar 11 2013, 10:43 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
How low is the car?
SirAndy |
Mar 11 2013, 11:48 AM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Stupid idea, but maybe a custom shim that is cut at an angle?
Thin on the outside and thick on the inside. In theory, that should give you more negative camber ... (IMG:style_emoticons/default/idea.gif) |
sixaddict |
Mar 11 2013, 12:30 PM
Thanks
Spoke to Chris this morning and first thing he said is LOWER the car....Or he should have said it in caps ...Been debating that with shop but he added some valuable info. May need to move spindles a bit to allow front to match but I am betting we are going down ! Thanks |
SirAndy |
Mar 11 2013, 03:54 PM
Stupid idea, but maybe a custom shim that is cut at an angle? Thin on the outside and thick on the inside. In theory, that should give you more negative camber ... (IMG:style_emoticons/default/idea.gif) Well, after giving this some more thought, the wedge would only work if you relocated (lowered) the mounting hole on the inner suspension ear. Still, that might be a viable option ... (IMG:style_emoticons/default/smash.gif) |
spaceshuttle |
Mar 16 2013, 09:24 PM
Member Group: Members Posts: 73 Joined: 25-November 06 From: SouthCarolina Member No.: 7,258 |
Thanks Spoke to Chris this morning and first thing he said is LOWER the car....Or he should have said it in caps ...Been debating that with shop but he added some valuable info. May need to move spindles a bit to allow front to match but I am betting we are going down ! Thanks Good thing you made your splitter/air dam removeable |
naro914 |
Mar 19 2013, 06:07 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Yes, you need to lower it.
And sell the 17" and go back to 16" wheels. |
Lo-Fi Version | Time is now: 9th May 2024 - 11:47 PM |
