Help adding rear negative camber |
sixaddict |
Mar 10 2013, 08:09 PM
Senior Member Group: Members Posts: 804 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Just corded another rear tire on outboard edge due to in adequate negative camber...Unable to get more than 1.8 - 1.9 ...All shims out.....
How can it be done without chopping up the car. Looking for at least 2.5 Thanks Terry |
SirAndy |
Mar 11 2013, 11:48 AM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Stupid idea, but maybe a custom shim that is cut at an angle?
Thin on the outside and thick on the inside. In theory, that should give you more negative camber ... (IMG:style_emoticons/default/idea.gif) |
SirAndy |
Mar 11 2013, 03:54 PM
Stupid idea, but maybe a custom shim that is cut at an angle? Thin on the outside and thick on the inside. In theory, that should give you more negative camber ... (IMG:style_emoticons/default/idea.gif) Well, after giving this some more thought, the wedge would only work if you relocated (lowered) the mounting hole on the inner suspension ear. Still, that might be a viable option ... (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 10:01 AM |
