Machinists and Fabricators, where can I get 1 of these made? |
McMark |
Mar 13 2013, 02:09 PM
I need a sleeve that's 41mm OD and 40mm ID. Can this be made? What process? Anyone have a lead on someone to do it? I only need 1 right now, but could order a bunch if the prototype works out.
billh1963 |
Mar 13 2013, 02:10 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
OU8AVW |
Mar 13 2013, 02:11 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
What's it made of? Other dimensions?
Need more info. |
McMark |
Mar 13 2013, 02:16 PM
20mm tall.
I don't really care what it's made out of. Once it's installed it doesn't move or take much load. |
andys |
Mar 13 2013, 02:22 PM
What are the tolerances? That's a pretty thin wall, but certaily doable. Let me check what stock I have on the shelf.
41x40x20, right? Andy1 |
McMark |
Hmmm, OD may be 40.75. That's pretty thin.
McMark |
Mar 13 2013, 02:55 PM
Ahh, figured it out. Happened to have some thin sheet metal around the shop and just made a 'shim'. Worked perfectly.
Gint |
Mar 13 2013, 10:05 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Speaking of shims... This evening I made some shims out of the plastic clam shell packaging that the phone car charger I bought came in. .007" thick, worked great. Finally found a use for that packaging crap!
Lo-Fi Version | Time is now: 15th May 2024 - 04:42 PM |
