McMark
Mar 13 2013, 02:09 PM
I need a sleeve that's 41mm OD and 40mm ID. Can this be made? What process? Anyone have a lead on someone to do it? I only need 1 right now, but could order a bunch if the prototype works out.
billh1963
Mar 13 2013, 02:10 PM
QUOTE(McMark @ Mar 13 2013, 04:09 PM)
What material?
OU8AVW
Mar 13 2013, 02:11 PM
What's it made of? Other dimensions?
Need more info.
McMark
Mar 13 2013, 02:16 PM
20mm tall.
I don't really care what it's made out of. Once it's installed it doesn't move or take much load.
andys
Mar 13 2013, 02:22 PM
What are the tolerances? That's a pretty thin wall, but certaily doable. Let me check what stock I have on the shelf.
41x40x20, right?
Andy1
McMark
Hmmm, OD may be 40.75. That's pretty thin.
McMark
Mar 13 2013, 02:55 PM
Ahh, figured it out. Happened to have some thin sheet metal around the shop and just made a 'shim'. Worked perfectly.
Gint
Mar 13 2013, 10:05 PM
Speaking of shims... This evening I made some shims out of the plastic clam shell packaging that the phone car charger I bought came in. .007" thick, worked great. Finally found a use for that packaging crap!
