| NorCalScott |
Oct 15 2026, 07:57 AM
Newbie ![]() Group: Members Posts: 46 Joined: 6-February 21 From: Sacramento Member No.: 25,173 Region Association: None |
@NorCalScott , my neighbor's engine shop has an Allstar pre-oiler and I'll give this a whirl with 1 quart or 2 of oil. After the pre-oil, I can also spin the engine on 'Starter motor; and just shut off spark and fuel pump. Pump belt removal + drill motor spinning always available too. Thanks Marty. Seems like every time you post updates, I learn something new. |
| Maltese Falcon |
Oct 15 2026, 08:54 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
@NorCalScott , my neighbor's engine shop has an Allstar pre-oiler and I'll give this a whirl with 1 quart or 2 of oil. After the pre-oil, I can also spin the engine on 'Starter motor; and just shut off spark and fuel pump. Pump belt removal + drill motor spinning always available too. Thanks Marty. Seems like every time you post updates, I learn something new. I first heard of the Pre-oiler trick on @tygaboy Chris 914 Ferrari thread, then set out to grab the tank from Summit. Then while having a cup of Java over at the engine shop, the guys said "You mean this tank over here?" Good neighbors ยก |
Lo-Fi Version | Time is now: 26th October 2026 - 06:24 PM |
