| Maltese Falcon |
Mar 6 2026, 03:14 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,451 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
| Maltese Falcon |
Mar 6 2026, 03:18 AM
| Maltese Falcon |
Mar 9 2026, 03:27 PM
Left polycarbonate vent window (IMG:style_emoticons/default/biggrin.gif) I will detail and just need to finish up with the 914Rubber upper-trim pieces.
| Shivers |
Mar 9 2026, 04:14 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,707 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Left polycarbonate vent window (IMG:style_emoticons/default/biggrin.gif) I will detail and just need to finish up with the 914Rubber upper-trim pieces. That is cool the poly came with a bug. If I was walking by I'd never notice, unless I leaned over and read it. |
| Maltese Falcon |
Mar 10 2026, 02:54 PM
Left polycarbonate vent window (IMG:style_emoticons/default/biggrin.gif) I will detail and just need to finish up with the 914Rubber upper-trim pieces. That is cool the poly came with a bug. If I was walking by I'd never notice, unless I leaned over and read it. Their Logo and info printed on the vent windows. Great website for Lexan, Polycarbonate race / custom windows, sliders, naca ducts ¡ |
| Maltese Falcon |
Mar 12 2026, 07:23 PM
Small bit of DIY info on these 'Repro trim pieces for the vent window tops; OE uses the 3mm set screws and these are supplied with the new kit.
However the new (repro) products are drilled/tapped at 2.5mm from this Co. These came in my 914Rubber seal kit , which we sourced several years ago/ maybe they have caught on to it and are supplying the correct size set screws now ¿ |
| burton73 |
Mar 13 2026, 01:06 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,102 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
@Maltese Falcon
Marty, the 2.5 screws look longer that the 3s. any problem? Best to you my brother, Bob b |
| Maltese Falcon |
Mar 13 2026, 06:06 PM
@Maltese Falcon Marty, the 2.5 screws look longer that the 3s. any problem? Best to you my brother, Bob b Brother Bob ¡ absolutely...that's just the random length these 2½ mm dia fasteners arrive from our supply haus>> we shave down to OE spec before installation (IMG:style_emoticons/default/sawzall-smiley.gif) |
| Maltese Falcon |
Mar 15 2026, 08:19 PM
| Maltese Falcon |
Mar 15 2026, 08:24 PM
| Maltese Falcon |
Mar 22 2026, 06:56 PM
| Maltese Falcon |
Mar 22 2026, 07:07 PM
| Maltese Falcon |
Mar 25 2026, 07:42 PM
| Maltese Falcon |
Mar 25 2026, 07:48 PM
| Maltese Falcon |
Mar 26 2026, 06:20 PM
Good way to handle/ and center the air cylinders into the corner space (IMG:style_emoticons/default/thumb3d.gif)
| Maltese Falcon |
Apr 1 2026, 04:10 PM
| Maltese Falcon |
Apr 1 2026, 04:12 PM
| Maltese Falcon |
Apr 1 2026, 04:19 PM
| Maltese Falcon |
Apr 2 2026, 08:25 PM
The 3rd air jack mounts center/ and just behind the fuel cell. The ball-valve in the pic is utilized as an equalizer to the rear 2 units; by setting either more or less air pressure to bleed out...the car will drop down more evenly all at once. Without this Equalization, either the front ½ of the car/or rear ½ of the car will drop down unevenly.
Attached thumbnail(s) |
| Maltese Falcon |
Apr 2 2026, 08:35 PM
Lo-Fi Version | Time is now: 3rd November 2026 - 07:11 PM |
