New Hoosiers and my suspension, What is going on? |
stuttgart46 |
Mar 26 2013, 11:13 AM
Member Group: Members Posts: 305 Joined: 17-December 07 From: Santa Monica, CA Member No.: 8,474 Region Association: None |
If the car feels as good as you say then don't do anything but drive it. I have several pictures of my race cars lifting wheels. It's no big deal and it makes for great pictures. LOL
J P Stein |
Mar 26 2013, 01:19 PM
OK Coach, tell us 95%ers how. OK, First you need a car that oversteers. By that I mean that if you come into any corner too hot (not on the brakes), does the back end step out?. That is oversteer and that's what I want. Not the hot ticket at track, but we ain't there. Then late apex ( not at 12 o'clock but at about 10-10:30) the cone. Come in hot & deep on a wide line.....maybe 1-1/2 or 2 car lenghts, get your braking done in a straight line and turn in hard, aiming for the backside of the come......you don't want any plow here ......all is not lost if you're too hot (to a point) cause the back end coming around is gonna help keep things semi-tidy. If you do that right you're already OTG but when you pass the cone's backside hard OTG....the back end comes loose but hang with it & unwind the wheel....learning to live with opposite lock is part of the drill. Do this right and it's fun & fast. You are already at a much higher speed than one that is toodling around the cone and the motor should on song......maybe as much as 10mph faster. .....thus the not quicker but faster bit. What you do with all that extra speed is up to you..... (IMG:style_emoticons/default/biggrin.gif) Sure, it takes some practice to develop the required judgement but what else youz' guys getting 8-12 runs at LPR got to do?.....besides use up your good tires. In hot, thrash around & exit hot.....the trashing around bit is what you want to eliminate. Practice, practice........ Once you got the drill down (and you'll know it when you feel it) one pass ought to do it for that corner. |
J P Stein |
Mar 26 2013, 01:55 PM
Here's a vid of doing a whole bunch wrong. The cone at the end is not 180 deg but 110 or 120 deg, but can see what I mean about oversteer.
http://www.youtube.com/watch?v=kgdDLsj8Vaw |
J P Stein |
Mar 26 2013, 01:59 PM
Woody |
Mar 26 2013, 02:10 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Nice DNF in the first one. (IMG:style_emoticons/default/poke.gif)
ww914 |
Mar 26 2013, 04:02 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
QUOTE +1 Have you attended any autox schools, as they're the best place to learn the basics and get lots of seat time. Of all the students I've instructed about 5% were out of the box good drivers. And even those people were missing one or two of the critical basics. If you're not feeling smooth it's likely you're driving the corner you're in as opposed to the next corner. Think about it...if you're looking at the next corner you'll naturally end up taking the corner you're in more smoothly. If you driving the corner you're in, then the exit on just about every corner will end up being a surprise. (IMG:style_emoticons/default/shades.gif) In autox we don't like surprises! Where do I keep an eye out for AX schools? |
Mar 26 2013, 04:26 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
get your braking done in a straight line and turn in hard Or, for those with less power that can't get their rear end to step out using the gas pedal, you can also get your braking done *while* you're turning in (trail-braking). If done correctly, it will have the same effect as described above ... (IMG:style_emoticons/default/popcorn[1].gif) |
Randal |
Mar 26 2013, 07:02 PM
get your braking done in a straight line and turn in hard Or, for those with less power that can't get their rear end to step out using the gas pedal, you can also get your braking done *while* you're turning in (trail-braking). If done correctly, it will have the same effect as described above ... (IMG:style_emoticons/default/popcorn[1].gif) +1 Yup. Various ways: As above, i.e, trail braking, Ebraking, powering the rear end out, oversteer built in or reachable through steering input, power or combination of both or downshifting and rapid release of the clutch. I've use the clutch trick on tight right or left handers at the Marina. Did it at Brad's suggestion and the car rotated so fast I had to laugh. It was simply insane how fast the car turned. Not sure it's good on the transmission, but it sure snapped the end around quick. (IMG:style_emoticons/default/biggrin.gif) BTW it only works when you are on a straight in third and end up with a right or left that is tight, but short. |
Randal |
Mar 26 2013, 07:05 PM
OK Coach, tell us 95%ers how. OK, First you need a car that oversteers. By that I mean that if you come into any corner too hot (not on the brakes), does the back end step out?. That is oversteer and that's what I want. Not the hot ticket at track, but we ain't there. Then late apex ( not at 12 o'clock but at about 10-10:30) the cone. Come in hot & deep on a wide line.....maybe 1-1/2 or 2 car lenghts, get your braking done in a straight line and turn in hard, aiming for the backside of the come......you don't want any plow here ......all is not lost if you're too hot (to a point) cause the back end coming around is gonna help keep things semi-tidy. If you do that right you're already OTG but when you pass the cone's backside hard OTG....the back end comes loose but hang with it & unwind the wheel....learning to live with opposite lock is part of the drill. Do this right and it's fun & fast. You are already at a much higher speed than one that is toodling around the cone and the motor should on song......maybe as much as 10mph faster. .....thus the not quicker but faster bit. What you do with all that extra speed is up to you..... (IMG:style_emoticons/default/biggrin.gif) Sure, it takes some practice to develop the required judgement but what else youz' guys getting 8-12 runs at LPR got to do?.....besides use up your good tires. In hot, thrash around & exit hot.....the trashing around bit is what you want to eliminate. Practice, practice........ Once you got the drill down (and you'll know it when you feel it) one pass ought to do it for that corner. Great explaination JP. You can do it in 222 next time I come up there! |
J P Stein |
Mar 26 2013, 09:15 PM
ww914 |
Mar 27 2013, 10:46 AM
Great explaination JP. You can do it in 222 next time I come up there! Well, I reckon.......my wrists are all swolt up right now but I'm hoping for a recovery. Then again, it ain't like ridding a bicycle. My last AX was down in Medford with you. Thanks for the driving tips guys. I cannot wait to get back on the track. I've got 7 inch wheels and rear coil over springs coming. I ordered 225 lb springs and will leave the rear sway bar off for now. |
Woody |
Mar 27 2013, 11:03 AM
jhadler |
Mar 27 2013, 02:23 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Already a bunch of good comments here...
If the car feels balanced right now, don't change it. So what if it's lifting a wheel? It's a rear wheel drive, rear weight biased car. Adding the rear bar might help keep the front wheel down, but will make wheel spin a much bigger issue. A mid engined car will always tend to unweight the inside front tire. The stiffer the roll bar in front, the more you are coupling the movement of the outboard (loaded) suspension with the inboard (unloaded) suspension. More coupling, more movement. When the outboard side compresses, so will the inboard, further unloading the inboard wheel. If you start lifting a REAR wheel, then you need to change something. Heck, I've seen championship winning cars that could clear a beer car with the inside front tire (usually in stock class though)... -Josh |
J P Stein |
Mar 28 2013, 09:36 AM
AX driving "tricks" to make a car do something are best avoided, IMO.
Bandaids are for there for repairing cuts. Let's look at trail braking to make the back end step out, for instance. Personally, I dialed out the step-out with the brake bias valve......I want control. Trail braking causes the front tires to do 2 things......slow the car and turn in. Remember the "traction circle"? I prefer using the all the grip for turn rather than to slow the car. When you get off the brake after turn in, the front un-weights the front tires.....grip changes again. Trail braking to me is an emergency situation cause I've screwed up and am too hot. Sure, all the driving schools teach trail braking but as JYS (a straight line breaker) says "How many F1 races has he won?" The same can be said (and I do) about those that preach the clutch tricks. Setting up a car to consistently behave as you want it is tough enough without muddying the waters with so called tricks. 914s are happiest when stuck to the pavement......or both end sliding the same amount (a true drift). With the latter, the dreaded snap spin is within a hairsbreadth......ayup, a spin. You can't drift a pusher. |
ww914 |
Apr 7 2013, 08:16 AM
OK, I am ready for Tuesday's corner balance. Here is what I have done so far in preparation:
Hoosier A6s on 7x15 Revolutions with 1/4" spacers (Wheels are very heavy but will have to do for now. Front: Bilstein struts New polybronze bushings All the neg camber I can get with moving the strut inboard (LF -1.1 deg RF -.6, measured with car level with a digital level.) 19mm anti-sway bar at softest position for now 22mm torsion bars Rear: Bilstein shocks with Ground Control coil overs 225 lb springs All the neg camber I can get by removing all shims. LR -1.8 degs RR -2.2 degs I guess when my man gets his equipment on the car, I will know more about what I have. I didn't bother measuring the toe as it will be aligned. Any suggestions on toe measurements and than book measurements? |
J P Stein |
Apr 7 2013, 08:31 AM
You need more front negative camber. Front grip is gonna your challenge, as I read your set-up.
I ran 0 toe at both ends AND as close as possible to 0 thrust angle. Don't overlook that aspect. The car will be "darty" on the road, OK, I am ready for Tuesday's corner balance. Here is what I have done so far in preparation: Hoosier A6s on 7x15 Revolutions with 1/4" spacers (Wheels are very heavy but will have to do for now. Front: Bilstein struts New polybronze bushings All the neg camber I can get with moving the strut inboard (LF -1.1 deg RF -.6, measured with car level with a digital level.) 19mm anti-sway bar at softest position for now 22mm torsion bars Rear: Bilstein shocks with Ground Control coil overs 225 lb springs All the neg camber I can get by removing all shims. LR -1.8 degs RR -2.2 degs I guess when my man gets his equipment on the car, I will know more about what I have. I didn't bother measuring the tow as it will be aligned. Any suggestions on tow measurements and than book measurements? |
ChrisFoley |
Apr 7 2013, 08:50 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Are you allowed to slot the strut towers to get more negative camber up front?
What's your ride height? Lowering the car a quarter inch will give you more negative camber. Did you make your measurements with your weight in the drivers seat? I would start with the a/s bar adjusted to the middle. I would set toe at zero front and rear. Toe in at the front is fine to compensate for stock tie-rods but doesn't benefit handling. Toe out at the front improves turn in at the expense of high speed stability. Toe in at the rear reduces oversteer, especially with a higher powered engine. Toe out at the rear will make the car spin easily. |
ww914 |
Apr 7 2013, 09:34 AM
Are you allowed to slot the strut towers to get more negative camber up front? What's your ride height? Lowering the car a quarter inch will give you more negative camber. I looked at the strut towers and it looks like if I slotted the holes, I would still have to modify the piece between the strut and the strut tower. Did you make your measurements with your weight in the drivers seat? No, that will be done on Tuesday. I just wanted to get it close. Maybe I will lower the car a little like you said. I would start with the a/s bar adjusted to the middle. I would set toe at zero front and rear. Toe in at the front is fine to compensate for stock tie-rods but doesn't benefit handling. Toe out at the front improves turn in at the expense of high speed stability. Toe in at the rear reduces oversteer, especially with a higher powered engine. Toe out at the rear will make the car spin easily. |
ChrisFoley |
Apr 7 2013, 04:01 PM
I looked at the strut towers and it looks like if I slotted the holes, I would still have to modify the piece between the strut and the strut tower. You can go until the camber plate hits the inside of the strut tower as long as you've already removed the shock cover tube. After that it takes aftermarket camber plates from Elephant, etc. or you can make your own the way I did, but you have to replace the rubber bushings with "Camber Balls" or a homemade spherical bearing setup. The way I made my first modified camber plates from stock pieces: Use a hole saw to cut out the center section around the bushing support flange. Then use the same hole saw to carefully cut out a crescent piece to the inside of the hole you just created. It may require temporarily tackwelding a plate over the big hole to provide a 1/4" center hole for the holesaw. Tack weld the center section back in place in the inner position. Make a new crescent shaped filler piece to finish the assembly and weld everything up solid. You could use the original cutout crescent but the holesaw removes a lot of metal and the gaps are awfully big to fill. Its a timeconsuming procedure so not feasible for a custom product IMO, but is a good DIY project for someone with the right tools. |
ww914 |
Apr 8 2013, 11:34 AM
The above sure seems like a hell of a lot of work to get 3/4 of a degree.
What I did in preparation for tomorrow's corner balancing is I lowered the front about 1/4" and matched up the two sides. Of course this is without me in the seat. I then matched the rear to the front for approximately equal right heights. I leveled the car in the garage and measured the toe again. Here is what I got this time: LR Old -1.8, new -2.8 LF Old -1.1, new -1.9 RR Old -2.2, new -2.6 RF Old -.6, new -1.1 We will see what they get tomorrow with accurate measuring devices. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:55 PM |
