Gauge Panel for Center Dash-Interest, ..."gauging" interest for a GB |
7TPorsh |
Apr 1 2013, 03:59 PM
Well I finally got it in and it looks pretty cool. Still need to wire it up. A little alteration to the existing plate and added my custom plate an viola; instant visibility.
I can have these made at a pretty reasonable cost that I can pass on. This panel is 16 ga. mild steel; but I think a little thinner will be the way to go. This variation has a hole for a x19 "console gauge" (clock in my case) and 4 holes for standard VDO gauges. With basketweave folded through, the gauges fit perfectly snug. Other variations could use either size. Hardest thing was getting the basketweave to line up... (IMG:style_emoticons/default/smile.gif) I would need at least 15 interested parties to make it work; preferable wanting the same configuration or similar. Price point will be roughly $40-45 delivered to CONUS. I await the raves and rants. Also have an extra one right now with the same configuration if anyone interested; had two made. |
JamesM |
Apr 1 2013, 05:17 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Its a clean look but costs you the heater contols and having to cut a bit into the stock dash.
For 5 gauges you can get the 3 gauge radio plate and the 2 gauge ashtray pod from rennmetal, have heat controls, and not cut up the dash. Not as clean but fully reverseable. |
Mike Bellis |
Apr 1 2013, 07:09 PM
I voted no because I like my heater and radio...
Lo-Fi Version | Time is now: 18th May 2024 - 11:51 AM |
