Paint fail. Well kinda., I see lots of color sanding in my near future. |
scotty b |
Apr 30 2013, 06:03 AM
Paint should go on to a smooth finish...I sanded with 1200 then shot with paint...then finish sanded to 3000 grit; then machine polished 2 stages. I think if you prep again up to 1200 or 1500 and a block then shoot. You will be better off. 1200 is WAY too fine for a final sanding before the base goes on. 600 is ideal, 1000 max. Above that and the base coat has little to grip to. At 1200 you're risking the base peeling loose of the primer at some point in the future. |
bulitt |
Apr 30 2013, 06:10 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Paint should go on to a smooth finish...I sanded with 1200 then shot with paint...then finish sanded to 3000 grit; then machine polished 2 stages. I think if you prep again up to 1200 or 1500 and a block then shoot. You will be better off. 1200 is WAY too fine for a final sanding before the base goes on. 600 is ideal, 1000 max. Above that and the base coat has little to grip to. At 1200 you're risking the base peeling loose of the primer at some point in the future. Ok Scotty, we are learning here. Whats the proper grit before- Primer on metal? Primer on FG? Base coat you said 600 Clear coat -shoot directly over base within manuf. time limit, or sand with ?grit? Thanks! |
7TPorsh |
Apr 30 2013, 11:36 AM
Paint should go on to a smooth finish...I sanded with 1200 then shot with paint...then finish sanded to 3000 grit; then machine polished 2 stages. I think if you prep again up to 1200 or 1500 and a block then shoot. You will be better off. 1200 is WAY too fine for a final sanding before the base goes on. 600 is ideal, 1000 max. Above that and the base coat has little to grip to. At 1200 you're risking the base peeling loose of the primer at some point in the future. Maybe a little smooth but I dusted the first light coat and let it dry for grip...looked rough at that point. then did the second coat and it went on smooth again. Still amazed how it came out for my first and only time painting anything bigger than a model. 3 coats and lots of sanding and polishing. 5 years and no peeling...a few chips here and there from my stupidity. I am not professional and am happy with the results. Total spend was like $110 for paint and gun; compressor I had. |
7TPorsh |
Apr 30 2013, 11:40 AM
Actually my first attempt was a roller job...DON'T DO THIS unless you like sanding and prepping everything twice. (IMG:style_emoticons/default/blink.gif)
Andyrew |
Apr 30 2013, 12:03 PM
Am I missing something here? Humidity, relative atmospheric pressure, field conditions, Elliot, etc... Then there is the unidentifiable issues... I went through this painting Peters car. I ended up faulting crappy paint and we just went with it. I still dont know what happend on that one. I still havent come across that issue again.. |
euro911 |
May 14 2013, 01:31 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Well ... (IMG:style_emoticons/default/popcorn[1].gif) ...
(I haven't been paying attention lately) (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
May 14 2013, 09:57 AM
did you say that the paint shop did it with the same results and now they are talking about what you prepped with? I think its the paint that needs to be questioned, not the people and process. rich As it turns out, the paint was bad after all. (IMG:style_emoticons/default/barf.gif) The body shop used it on a scrap hood and it turned out really crappy. The painter said he could tell from the way it came out of the gun, that something was bad wrong. They bought more of the same paint, shot it with the same gun and it went on perfectly. The guys from the paint store looked at it, decided it was bad (they said it didn't even smell right)? (IMG:style_emoticons/default/confused24.gif) and gave me more paint. Hopefully they will shoot it again this week. Kind of a bummer that my first attempt at this was hampered by some shitty paint. |
May 14 2013, 11:24 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
sucks when its not your fault
Great you are learning...now you know what "good paint" should smell like....not that it will come in handy in the future. rich |
ruby914 |
May 14 2013, 08:03 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
sucks when its not your fault Great you are learning...now you know what "good paint" should smell like....not that it will come in handy in the future. rich (IMG:style_emoticons/default/agree.gif) Attached image(s) |
moparrob |
May 15 2013, 09:24 AM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
"No way dude, that paint looked fine when I sold it to you..."
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1368631468.1.jpg) |
76-914 |
May 15 2013, 01:57 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Really, the Dude mixing your paint didn't catch that. Mix some brake fluid in with his car polish. (IMG:style_emoticons/default/happy11.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 02:30 PM |
