| 914itis |
Apr 5 2013, 08:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Car run great! With a a little rattling / rubing sound .it has been that way for over a year, with a litle time in my hands, I decide to trouble shoot. I check everywhere thinking that I may have dropped a bolt, somewhere , none. Check the belt, tight . While checking the heat exhangers, I noticed it was coming by the fuel pump, yes it is the fuel pump.
I had a spare pump, I decided to replace it, the noise on the second pump was almost unbearable. Oh well! Just wanted to share. |
| Madswede |
Apr 6 2013, 12:45 AM
Flat Out Driver ![]() ![]() ![]() Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
When my car had the carbed bus motor in it, the low-P fuel pump made lots of noise for a couple days before it died. Tapped it with a hammer a couple times, and it worked and quieted down. My only conclusion from that was that it needed attention. (IMG:style_emoticons/default/confused24.gif)
| mepstein |
Apr 6 2013, 06:23 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,024 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Paul - I have a 2 port if you need it. $n/c. I can bring to hershey or ship if you need it now. Mark
| rhodyguy |
Apr 6 2013, 06:36 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
carbs or fi?
k |
| 914itis |
Apr 6 2013, 06:58 AM
Gentkemen,
I don't think there is anything Wong other then, thy are just noisy. It is fuel injection and the 2 port pumps. Scott, the car belong to the previous owner of the body shop. The new owner pushes it out as he needed the space. I have his number and have been tryng to contact him with no answer. His voice mail is full. I was also told that the engine was a 2270. I will keep you posted . |
| rhodyguy |
Apr 6 2013, 07:31 AM
2270 with stock d or ljet? either way your pump shouldn't make a bunch of noise.
| rhodyguy |
Apr 6 2013, 07:32 AM
| 914itis |
Apr 6 2013, 07:44 AM
It is a 2.0 djet, the first pump is not that noisy, just a small noticeable rattle . The replacement was loud. The are both Bosch with different part numbers.
| 76-914 |
Apr 6 2013, 08:57 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,995 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Paul, from your description I take it that it is still mounted under the battery. Is is still mounted on the factory vibration isolators?
| 914itis |
Apr 6 2013, 09:33 AM
Lo-Fi Version | Time is now: 27th November 2026 - 07:05 PM |
