> Suspension noise?
dmilzoff
post May 19 2003, 04:52 PM
I have a 1970 914-6 with a low pitched pulsing hum. It only happens when I make a slow right turn at low speed (at high speeds the engine may obscure the noise.) It seems to be the front right wheel. The tire has plenty of clearance. Tie rod? Wheel bearings? Any ideas on a way to track down the cause and solution?
Replies(1 - 2)
Gint
post May 19 2003, 05:00 PM
Mike Ginter
Step on the go/loud pedal and forget about it.
Sorry. I'm sure your serious. Jack the front of the car up and grab the wheel(s) at noon and 6 and check for loose wheel bearings. Grab at 3 and 9 and wiggle to check for tie rod play. Take a pal out there and have him/her move a wheel right to left and check the steering shaft and rack for movement. This little exploratory should give you a better idea what's wrong. Or at least give us a better idea of what it may be based on your results.
post May 19 2003, 05:15 PM
Resident German
QUOTE(dmilzoff @ May 19 2003, 03:52 PM)
sounds like a wheel bearing ...
- Lo-Fi Version Time is now: 4th March 2026 - 04:37 PM
