stuttgart46 |
Member ![]() ![]() Group: Members Posts: 305 Joined: 17-December 07 From: Santa Monica, CA Member No.: 8,474 Region Association: None ![]() |
I'm in the middle of a conversion to a 6 and I was curious to see if you guys that have done this retain your wiring harness or do you fabricate a new one.
Does anybody make one for purchase or are they typcially custom built? TIA Chad |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,060 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Perry on this board makes Very nice engine harnesses for 6's.
http://www.914world.com/bbs2/index.php?sho...amp;mode=linear |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I REALLY don't like "ditto" posts, but I am making an exception. Like Jeff Bowlsby's FI and engine harnesses for the 4 cylinder cars, Perry's /6 harnesses are a thing of beauty, things you can't just knock out yourself, done better than you ever could.
The Cap'n |
stuttgart46 |
Thanks for the heads up guys.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
1st conversion: I used the /4 engine harness and matched function (not color) of the wires. I tied the /4 into the /6 engine harness and taped off the unused wires of the /6 harness. I also used the /4 relay board.
2nd conversion: Pulled the 911 connector plate and tied in the /4 main body wires again matching function. 3rd conversion: Used the /4 main harness and wired direct to the /6 engine harness. 4th conversion: Will use the 914 14 pin main connector with a mating 14 pin connector from the 911 engine harness. That said, I am a CASOB and Perry's harnesses are nice!!!!! |
Lo-Fi Version | Time is now: 30th July 2025 - 04:03 PM |
