V8 guys...oil pan "lower" than the floor pan???? |
Mueller |
Nov 21 2004, 07:34 PM
it looks like I need to lower the engine/transmission assembly at least an inch more than how I have it test fitted into my car ( rear trunk hits the motor when closed, duh!!!! (IMG:style_emoticons/default/headbang.gif) )
if I lower the transmission an inch and the front of the motor a little more I should be okay, I am just worried of having the oil pan too low....I'm guessing as long as it is not lower than a stock /4 engine mount I should be okay...thoughts??? |
redshift |
Nov 21 2004, 07:54 PM
On my V8, the oil pan determined ride height.
You can think of something custom.. (IMG:style_emoticons/default/smile.gif) What was the verdict on the placement in the end? Are you still running the transaxle forward 1.5 inches? M |
Joe Bob |
Nov 21 2004, 07:56 PM
What part of the engine is hitting?
Mueller |
Nov 21 2004, 08:00 PM
I pretty much "have" to run the transmission foward that much, possibly even 2 or 2.5"...the darn camshaft gears are on the back of the head, so no way I can modify the camshaft cover.........I have no idea what the moving of the transmission is going to do to my axles (IMG:style_emoticons/default/wacko.gif)
Mueller |
Nov 21 2004, 08:05 PM
QUOTE(mikez @ Nov 21 2004, 06:56 PM) What part of the engine is hitting? engine to chassis interferance the head sits too high...hits the trunk in rear, and on the front of the engine, the belt tensioner, fuel rail and some parts of the head hit the firewall... |
redshift |
Nov 21 2004, 08:14 PM
It's going to stress your CVs, that's what.
the more acute the angle, the uglier she gets, Cappy.. cam gears on.. the.. I have seen a V8 with a big intake/redneck thing, that came up thru maybe... 3-4 inches of the leading edge of the trunk lid.. the trunk floor was boxed in around it.. But, the axle geometry was right... There has to be a tricked out oil pan for that motor, low profile.. hmm.. M |
neo914-6 |
Nov 21 2004, 09:43 PM
Mike,
Maybe a solution for the bottom clearance: dry sump Opps, not sure if this is four or six... Looks great! Another pioneer... (IMG:style_emoticons/default/smilie_pokal.gif) Felix |
skline |
Nov 21 2004, 11:53 PM
Another Pioneer? Or another Prisoner???
You go so far and you pass the point of no return. Seems to me, he is past that stage now. He has to make it work. |
sixnotfour |
Nov 22 2004, 12:29 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Attached File(s) oilrear.bmp ( 18.45k ) Number of downloads: 22 |
Toast |
Nov 22 2004, 12:30 AM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Moroso, et all, make shallow winged pans for SBs & BBs. The LS1 Corvette, Camaro, Firechicken all have winged pans for clearance.
Dry sump would be great, but the cost is outlandish (at least for my pocket) |
SLITS |
Nov 22 2004, 12:32 AM
Oooops
redshift |
Nov 22 2004, 12:33 AM
QUOTE(sixnotfour @ Nov 22 2004, 02:29 AM) We build our stills up in the woods, or at least in tall grass. M |
Mueller |
Nov 22 2004, 12:34 AM
QUOTE(skline @ Nov 21 2004, 10:53 PM) Another Pioneer? Or another Prisoner??? You go so far and you pass the point of no return. Seems to me, he is past that stage now. He has to make it work. right now I'd say prisoner (IMG:style_emoticons/default/laugh.gif) I cut the rear trunk to make it fit with the transmission in the stock location.....not good, targa top hits the motor as well as the rear deck lid when closed.....time to make some custom transmission mounts (IMG:style_emoticons/default/smash.gif) |
redshift |
Nov 22 2004, 12:35 AM
just cut the roof out a little.
m |
McMark |
Nov 22 2004, 12:36 AM
What about an input shaft extender and a bell housing extender? (IMG:style_emoticons/default/biggrin.gif) Then your tranny will be in the stock location. (IMG:style_emoticons/default/idea.gif)
Mueller |
Nov 22 2004, 12:56 AM
QUOTE(markd@mac.com @ Nov 21 2004, 11:36 PM) What about an input shaft extender and a bell housing extender? (IMG:style_emoticons/default/biggrin.gif) Then your tranny will be in the stock location. (IMG:style_emoticons/default/idea.gif) you been sniffing that brake cleaner again? (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/wacko.gif) |
redshift |
Nov 22 2004, 12:59 AM
lmao.... billet!
Lo-Fi Version | Time is now: 17th May 2024 - 06:14 PM |
