> 914/4 injector, Voltage
gifted914
post Apr 17 2013, 09:19 PM
middleagecrisis
Region Association: Australia and New Zealand
G'day all.
Does anyone know the operating voltage and amps on the injector.
I dont't thing it is straight 12 volts.
Peter
Mike Bellis
post Apr 17 2013, 09:30 PM
Resident Electrician
It is a 12V injector. The amperage is in the mili amp range. Measure the resistance and use Ohm's Law to solve for current.
Dave_Darling
post Apr 17 2013, 10:43 PM
914 Idiot
The 1.8s have the resistor pack which drops the voltage going to the injectors.
The 1.7 and 2.0 ECUs do not supply 12V, either.
Hmm, actually: according to the D-jet bible, the D-jet injectors see a peak of just over 12V, and are held open by 4-5V.
http://members.rennlist.com/pbanders/ecu.htm#D1-D2
--DD
gifted914
post Apr 18 2013, 01:13 AM
middleagecrisis
QUOTE(Dave_Darling @ Apr 18 2013, 02:43 PM) *
--DD
thanks (IMG:style_emoticons/default/beerchug.gif)
gifted914
middleagecrisis
QUOTE(kg6dxn @ Apr 18 2013, 01:30 PM) *
Thanks (IMG:style_emoticons/default/beerchug.gif)
sofi2t81
post Apr 18 2013, 08:48 AM
Region Association: Germany
I talked with a Bosch guy at the Techno Classica in Essen (Germany) who gave a short presentation about the D-Jet.
The Voltage from the ECU is 3V!
Peter
gifted914
post Apr 18 2013, 03:53 PM
middleagecrisis
QUOTE(sofi2t81 @ Apr 19 2013, 12:48 AM) *
Peter
Thanks for the info.
Peter (IMG:style_emoticons/default/beerchug.gif)
Spoke
post Apr 18 2013, 06:07 PM
Jerry
QUOTE(sofi2t81 @ Apr 18 2013, 10:48 AM) *
Peter
Keep in mind that the 3V is output only when loaded with the injector. If one were to disconnect the injector, the output is actually 12V.
There is a resistor between the switched 12V and the output. The resistor is about 6 ohms (6.15 ohms in P Anders website). The resistor limits the current through the injector and the voltage across the injector.
The injector resistance is 2.67 ohms in P Anders website.
One calculates the voltage across the injector to be a resistor divider between the internal 6.15 ohms and 2.67 ohm injector.
So with the injector, the measured voltage would be : 12V x 2.67 / (2.67 + 6.15) = 3.6V.
The injector current would be limited by the injector and internal resistances: 12V/(2.67 + 6.15) = 1.36 Amperes
If you want to test an injector, use 12V with 6 ohms in series with the injector.
The 6 ohm resistor does have to be a power type. Power calculated by I x I x R = 1.36A X 1.36A X 6 = 11 Watts. A 5W resistor would do since one would be pulsing the injector on and off to test (assumption).
Sorry to get so technical.
- Lo-Fi Version Time is now: 20th January 2026 - 01:14 PM
