Stuck rocker cheesehead screws, The three on the bottom |
moldygreg |
Apr 18 2013, 11:26 PM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
First time these rockers have been off ever! Drilled out original rivets and then cleared out three ponds of dirt! Amazingly, rust free!
Anyway, the damn three cheesehead screws won't budge. Snapped one off and will have to drill out (another fun project forthcoming) Currently blasting and letting them soak 24 hours with penetrating lube from Tacoma screw http://www.tacomascrew.com/s.nl/it.A/id.61346/.f Questions: Is there a penetrating bolt busting lube that reigns supreme or is mine good enough? How long should I wait? Any other tips? I don't have access to a welder so I can't tack on a better bolt head to loosen unfortunately. I also have mapp gas, but the rocker panel seems like it's acting like a heat shield and I suspect isn't getting the bolt hot enough. (IMG:style_emoticons/default/smash.gif) |
rhodyguy |
Apr 19 2013, 03:24 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Aero Kroil works well. tacoma screw products or online. that you have to get the product to defy gravity doesn't help much. esp on the top of the threaded hole/tip of the screw so it can drain down.
k |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:04 AM |
