Stuck rocker cheesehead screws, The three on the bottom |
moldygreg |
Apr 18 2013, 11:26 PM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
First time these rockers have been off ever! Drilled out original rivets and then cleared out three ponds of dirt! Amazingly, rust free!
Anyway, the damn three cheesehead screws won't budge. Snapped one off and will have to drill out (another fun project forthcoming) Currently blasting and letting them soak 24 hours with penetrating lube from Tacoma screw http://www.tacomascrew.com/s.nl/it.A/id.61346/.f Questions: Is there a penetrating bolt busting lube that reigns supreme or is mine good enough? How long should I wait? Any other tips? I don't have access to a welder so I can't tack on a better bolt head to loosen unfortunately. I also have mapp gas, but the rocker panel seems like it's acting like a heat shield and I suspect isn't getting the bolt hot enough. (IMG:style_emoticons/default/smash.gif) |
76-914 |
Apr 19 2013, 05:45 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
twist 'em off if they won't budge after soaking. then install rivenuts where you need 'em.
Lo-Fi Version | Time is now: 3rd May 2024 - 02:21 AM |
