installed a hi torque starter |
rfuerst911sc |
Apr 22 2013, 03:43 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
The Bosch starter on my 3.0 conversion had been acting up and recently stopped engaging I believe the solenoid is shot. Ordered a IMI hi torque starter from GPR two weeks ago and installed it yesterday. The old starter I was told was a 911 starter from a turbo I believe they call it a 930X. After removal I compared the old starter to the new. In regards to the nose piece depth looked the same and they both had 9 teeth on the pinion gear. New starter was considerably smaller in overall size and lighter. Bolted right up and all the wiring reached with no issues. I did not have to " clock " the starter the way it arrived was the way I installed it. Lowered the car off the lift ( best tool ever ) and connected the battery. Turned the key and there was that seeet music of the motor turning over ! (IMG:style_emoticons/default/biggrin.gif) So for the record if this helps anyone this is a 1978 911SC motor with stock flywheel, Kennedy Engineering ring gear adapter and a IMI starter. Oh and the previous starter was installed with conventional hex nuts and that's what I reused. Works great.
Lo-Fi Version | Time is now: 18th May 2024 - 05:02 AM |
