Need longer throttle cable, where to get? |
machina |
Nov 23 2004, 12:44 PM
Need an extra 18", ran cable from rear of case to pull throttle bar on webers. The short cable I have now feels terrible because of the tight radius.
Morse makes nice push/pull but would have to adapt the fittings. Need source for stock type (but longer) cable. |
Brett W |
Nov 23 2004, 01:05 PM
Are you running your carbs and linkage backwards? How about a pic or two.
aircooledboy |
Nov 23 2004, 01:09 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
I just got a pre-made accel. cable from renegade for my 8. It is a Terry cable w/ the right fittings, but I think it is 18 inches longer than stock.
machina |
Nov 23 2004, 01:45 PM
QUOTE(aircooledboy @ Nov 23 2004, 02:09 PM) I just got a pre-made accel. cable from renegade for my 8. It is a Terry cable w/ the right fittings, but I think it is 18 inches longer than stock. That's what I'm talking about. Guess I'll call renegade. Won't tell them I have a measley type IV (IMG:style_emoticons/default/happy11.gif) Pic as requested.... Attached image(s) |
Aaron Cox |
Nov 23 2004, 01:54 PM
flip the pull arm up make a bracket
looking for pic... |
Aaron Cox |
Nov 23 2004, 01:55 PM
machina |
QUOTE(Aaron Cox @ Nov 23 2004, 02:54 PM) flip the pull arm up make a bracket looking for pic... Yah, but this one goes to 11, have pics but thanks. |
URY914 |
Nov 23 2004, 02:24 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,626 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Thats kinda strange because my set up is about the same and my stock cable is long enough.
Do you have the long wheelbase model? Paul |
Aaron Cox |
Nov 23 2004, 02:46 PM
QUOTE(synthesisdv @ Nov 23 2004, 12:55 PM) QUOTE(Aaron Cox @ Nov 23 2004, 02:54 PM) flip the pull arm up make a bracket looking for pic... Yah, but this one goes to 11, have pics but thanks. (IMG:style_emoticons/default/wacko.gif) huh? |
machina |
Nov 23 2004, 03:58 PM
QUOTE(URY914 @ Nov 23 2004, 03:24 PM) Do you have the long wheelbase model? Paul No just a standard 914 tub. It reaches OK but the throttle travel feels terrible, I can hardly modulate it in a turn which can be dangerous. Really can't get the most out of the car with the throttle like it is. Maybe I got a lousy cable to start with. I gotta do something about it. Attached image(s) |
Brett W |
Nov 23 2004, 11:11 PM
I agree.
Turn the lever around and pull from the front or build some sort of linkage like the 914-6 used. I have never really been a fan of the goofy cross bar linkage. I have a bell crank system that works better than any other system I have seen or worked with. No I don't have a picture of it. What do you have for return springs? I have found that really weak or insufficent return springs can make a car impossible to drive smoothly. Another thing is the location of those return springs. Always mount your return springs on the same side of the carb as the linkage rods. This will minimize twist in your throttle shafts thus creating uneven carb syncronization. |
rick 918-S |
Nov 24 2004, 12:08 AM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
QUOTE(aircooledboy @ Nov 23 2004, 11:09 AM) I just got a pre-made accel. cable from renegade for my 8. It is a Terry cable w/ the right fittings, but I think it is 18 inches longer than stock. How much was the cable? I need a longer cable too. |
slivel |
Nov 24 2004, 09:37 AM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
I recommend Terrycable. They have supplied both accel and clutch cables for me. They will do custom length. http://www.terrycable.com/
Steve |
URY914 |
Nov 24 2004, 10:22 AM
QUOTE(synthesisdv @ Nov 23 2004, 01:58 PM) QUOTE(URY914 @ Nov 23 2004, 03:24 PM) Do you have the long wheelbase model? Paul No just a standard 914 tub. Dave, you may not realize this but by the looks of your car, it is a little different than most. Is yours the engine the striaght 12 cylinder, front engine option? Very rare. (IMG:style_emoticons/default/ohmy.gif) Paul |
aircooledboy |
Nov 24 2004, 01:07 PM
QUOTE(rick 918-S @ Nov 24 2004, 12:08 AM) How much was the cable? I need a longer cable too. Unfortunatey Rick, I don't know. (IMG:style_emoticons/default/laugh.gif) I bought it at the same time I got a bunch heater parts while I was out there, and Mike jokingly said "how much money ya got". Well I had 60 bucks, so he said "close enough". Hell, the heater parts alone had to be at least 50, so I don't know what they are asking for the cable. So, as my kids are so fond of saying: idunno. (IMG:style_emoticons/default/monkeydance.gif) |
cametal |
Nov 24 2004, 07:30 PM
autox'n Group: Members Posts: 76 Joined: 28-July 03 From: Oklahoma City, OK. Member No.: 960 |
I think that the stock 914-6 cable is longer than the 4 cyl. one and might be cheaper than a custom one.
Lo-Fi Version | Time is now: 17th May 2024 - 06:11 PM |
