correct way to handle car battery, Never been sure about it |
Matt Meyer |
Nov 24 2004, 05:21 PM
Überlurker Group: Members Posts: 216 Joined: 2-December 03 From: Eastern Washington Member No.: 1,411 Region Association: Pacific Northwest |
I hope this helps. A little simplified but...
If either terminal (plus or minus) is disconnected from the battery then the battery will not discharge. The entire car body, engine, transmission and half of each electrical component is connected to the negitive (on our 914s) by the ground. So if you touch the body and the negitive terminal then nothing. (IMG:style_emoticons/default/smile.gif) They are already "touching" by the ground straps. If while removing the positive terminal first you touch almost anything, then you will be creating a short. A short occurs because almost everything is grounded to the negitive side of the battery. Sparks will fly. The wrench may weld to the whatever you are touching. If you have been charging the battery it could explode. (IMG:style_emoticons/default/ohmy.gif) DO NOT DO THIS. Removing the GROUND wire, negitive on the 914, will prevent everything electrical from working. This is the safe condition. ALWAYS DISCONNECT THE GROUND FIRST |
iiibdsiil |
Nov 24 2004, 10:29 PM
Needs Door Locks Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
QUOTE Back up a step, this is all about how to disconnect the battery in the first place. Okay, I thought we were past that. My bad, sorry about that. I jumped ahead. QUOTE iiibdsiil I think this is the main reason to disconnect the (-) first. Can you honestly say that you have been removing the Pos (+) side before the neg (-) and have never touched the wrench to the body an sparks went flying. If so you are lucky. I need to buy a lotto ticket now. Lol. I haven't been fortunate enough yet, although I am sure it will happen Monday at work now that you jinxed me. (IMG:style_emoticons/default/finger.gif) (IMG:style_emoticons/default/laugh.gif) |
bare 1 |
Nov 25 2004, 12:29 AM
Member Group: Members Posts: 122 Joined: 27-October 04 From: Apache Junction viaWhidbey Is. Member No.: 3,019 Region Association: None |
So a what's the first thing I want to do when I pull my engine????
hargray2 |
Nov 25 2004, 12:53 AM
fuh-q Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 |
disconnect the NEG on the battery. (IMG:style_emoticons/default/lol2.gif)
F4i |
Nov 25 2004, 01:21 AM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
I have personally seen a few things. 1. Batteries will and do explode 2. wedding rings conduct and have sufficient resistance to get hot. 3 wrenches are excellent conductors and thats why neg first.
Curvie Roadlover |
Nov 25 2004, 06:52 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
QUOTE(iiibdsiil @ Nov 24 2004, 02:15 PM) Never seen a battery explode, never even met someone that has seen a battery explode. I know someone that was working on a car and the battery exploded. The car he was working on was a 914. This was in 1978 and he still bears scars on his face from the accident. Disconnect neg. first. Always |
Lo-Fi Version | Time is now: 1st June 2024 - 12:18 PM |
