> 2 stage paint
914itis
post May 1 2013, 04:50 PM
Post #41
I sprayed a 2 stage paint for the first time. I primed with a 2 k primer cut with thinner, waited an hour spray the base coat, 3 coats then clear coat.
I am not sure If i miss some spots or if it is a reaction, for some reason, I can see the primer under the paint. It's hard to see but can be seen with enough lighting.
It can be see in a few areas.
What did I do wrong and how do I correct this ?
914itis   2 stage paint   May 1 2013, 04:50 PM
bulitt   Dont have a clue, but the experts will want to kno...   May 1 2013, 05:16 PM
Andyrew   How many coats of base did you use? Depending on...   May 1 2013, 05:28 PM
ThePaintedMan   :agree: I don't have near the experience as ...   May 1 2013, 05:34 PM
914itis   I sprayed 3 coats, the primer is grey and the pain...   May 1 2013, 06:59 PM
ThePaintedMan   Red is a thin pigment as well and sometimes requir...   May 1 2013, 07:42 PM
PanelBilly   I think you have an expensive guide coat at the po...   May 1 2013, 08:10 PM
McMark   What line of PPG? If it's OMNI (the cheap stu...   May 1 2013, 09:23 PM
914itis   Yes , Omni. I asked for good stuff and that's ...   May 1 2013, 09:25 PM
McMark   WOW. :blink: Don't ever go back to that pain...   May 1 2013, 09:30 PM
ThePaintedMan   WOW. :blink: Don't ever go back to that pai...   May 1 2013, 09:32 PM
a914622   Is it thin all over or just a door bottom or somet...   May 1 2013, 10:23 PM
914itis   No, It is not all over. I have 3 small spots. un...   May 1 2013, 10:41 PM
ThePaintedMan   Ah, I know what you did then. You just simply miss...   May 1 2013, 11:26 PM
914itis   Ah, I know what you did then. You just simply mis...   May 1 2013, 11:36 PM
bulitt   Paul- You want the Deltron Line from PPG, primer, ...   May 2 2013, 05:02 AM
914itis   I spoke to the clown at the paint shop . He told m...   May 2 2013, 06:17 AM
timothy_nd28   I think a step was left out, the sealer coat after...   May 2 2013, 07:04 AM
rick 918-S   When I had my shop the DuPont rep would pull the s...   May 2 2013, 07:11 AM
914itis   When I had my shop the DuPont rep would pull the ...   May 2 2013, 07:25 AM
scotty b   PM sent Your paint supplier is an absolute idiot....   May 2 2013, 07:16 AM
Andyrew   Paul, At this point I think your best bet is to ...   May 2 2013, 07:35 AM
scotty b   Paul, At this point I think your best bet is to...   May 2 2013, 07:40 AM
Andyrew   Makes sense. I had a fear of solvents escaping whi...   May 2 2013, 07:54 AM
914itis   I am shopping for new paint. 1- whats a good bra...   May 2 2013, 09:00 AM
a914622   If the spots are small enough or there is a small ...   May 2 2013, 09:27 AM
914itis   Any one heard of LUSID technology paint?   May 2 2013, 10:24 AM
bulitt   You need to call Scotty. And here is my guess why...   May 2 2013, 11:32 AM
scotty b   First off, when you go in with a code for these ca...   May 2 2013, 12:36 PM
ThePaintedMan   First off, when you go in with a code for these c...   May 2 2013, 12:47 PM
bulitt   First off, when you go in with a code for these c...   May 2 2013, 02:29 PM
scotty b   Shopline is only available through the " plat...   May 2 2013, 06:52 PM
scotty b   double dirka   May 2 2013, 06:53 PM
914itis   double dirka :confused:   May 2 2013, 07:05 PM
scotty b   double dirka :confused: interweb connection h...   May 2 2013, 07:38 PM
914itis   Update I manage to sand down to the paint and rep...   May 4 2013, 07:09 PM
914itis   More   May 4 2013, 07:11 PM
bulitt   Yup. the clear should come out fine. Be careful s...   May 4 2013, 07:15 PM
Andyrew   Can you put a florescent above and take another sh...   May 4 2013, 07:48 PM
914itis   Yes it is the clear only.   May 4 2013, 07:51 PM
scotty b   that Is orange peel. Wet sand it. If you want to b...   May 4 2013, 07:56 PM
Andyrew   that Is orange peel. Wet sand it. If you want to ...   May 5 2013, 11:38 AM
914itis   Thanks all, will start wet sanding in 24 hours and...   May 4 2013, 08:15 PM
914itis   Scotty, What color code was this? you posted this ...   May 5 2013, 11:02 AM
scotty b   Scotty, What color code was this? you posted this...   May 5 2013, 02:40 PM
914itis   Scotty, What color code was this? you posted thi...   May 5 2013, 08:06 PM
914itis   Another 4 Hours of wet sand today. that makes it a...   May 6 2013, 08:52 PM
scotty b   2 DO NOT buff those spots before doing this. now...   May 7 2013, 06:00 AM
914itis   Thanks, is there a time frame to buff after wetsan...   May 7 2013, 06:05 AM
scotty b   Thanks, is there a time frame to buff after wetsa...   May 7 2013, 11:51 AM
914itis   Update After gathering everyone's profession...   May 14 2013, 09:34 AM
scotty b   :beer2:   May 14 2013, 06:13 PM
rick 918-S   Glad it worked out for you.   May 14 2013, 06:17 PM
914itis   Final product.   May 21 2013, 06:52 PM
ThePaintedMan   Way to go Paul! You did it right by repainting...   May 21 2013, 07:04 PM
914itis   Thanks, a bit of patience, and yes I learned a lot...   May 21 2013, 07:20 PM
914itis   iPhone and glare from the hot sun today. Scotty w...   May 21 2013, 07:33 PM
76-914   That really looks good Paul. :poke: Is your son ...   May 21 2013, 07:54 PM
914itis   That really looks good Paul. :poke: Is your son...   May 21 2013, 08:43 PM
Andyrew   Looks great!   May 21 2013, 10:16 PM
saigon71   Paul: Must have been frustrating as hell going th...   May 22 2013, 06:27 AM
jimkelly   good paint video - epoxy primer, 2k primer, base c...   Sep 10 2013, 09:10 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:36 PM
