Cleaning cylinder, what to use to not damage |
dfelz |
May 1 2013, 09:49 PM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
the top lip of the inside of the cylinder has some carbon buildup and i would like to clean this off before reassembling on the engine tomorrow with Ethan. How should i go about cleaning this (see pic) as to not damage the rest of the surfaces? Thanks!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1367466567.1.jpg) |
messix |
May 1 2013, 10:34 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
carb cleaner and a scotch bright pad
dfelz |
May 1 2013, 11:00 PM
I'll give that a shot right now, i have both of those products in my garage (IMG:style_emoticons/default/biggrin.gif) thanks
'73-914kid |
May 1 2013, 11:31 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
If the carb cleaner doesnt work, ATF works awesome. The extremely high detergent in ATF helps break it down.
dfelz |
May 2 2013, 12:55 AM
If the carb cleaner doesnt work, ATF works awesome. The extremely high detergent in ATF helps break it down. I may have some ATF, I'll have to look in my box of fluids! the carb cleaner did so-so, i also only had the Mr. clean magic erasers on hand, and i think the scotch bright has a little more bite to it so ill be grabbing one of those tomorrow too. Must have them ready before you come over! |
jpanzer51 |
May 2 2013, 05:08 AM
Newbie Group: Members Posts: 1 Joined: 17-April 10 From: Western Ct Member No.: 11,627 Region Association: North East States |
Try Windex All Surface cleaner, It cleans the burnt -on carbon off the glass on my wood stove.
Carb cleaner & lacquer thinner wouldn't touch it. |
bulitt |
May 2 2013, 05:12 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Seriously tough deposits can be removed with a ridge reamer. Can rent at a tool rental place, uses a hand drill. Did you hone that cylinder? looks pretty shiny.
dfelz |
May 2 2013, 08:49 PM
Alright, so I got a scotch bright tough scrub pad and it worked like a charm!! Tried the windex but it left a weird residue while i was scrubbing and the carb cleaner worked fine so i stuck with that.
bulitt, the cylinders dont have many miles on them from what i can tell, those hone lines are the original ones! Thanks for the help guys (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1367549368.1.jpg) |
Razorbobsr |
May 3 2013, 05:35 AM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
Try Windex All Surface cleaner, It cleans the burnt -on carbon off the glass on my wood stove. Carb cleaner & lacquer thinner wouldn't touch it. Try Easy Off stove cleaner, works best when fireplace is worm to med hot. Bob Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:53 AM |
