5 lug conversion, Front disc assembly is larger than stock |
viaverde |
May 5 2013, 10:23 AM
Aubergine Gene (sold the Aubergine 914) Group: Members Posts: 9 Joined: 28-January 10 From: Claremont, CA Member No.: 11,301 Region Association: Southern California |
I have a front 5 lug assembly that I believe is a direct bolt on to the spindle....come to find that the bearings are larger than the original spindle...further reading on Pelican says that the 911 has a "beefier" spindle..... Now what? Replace front spindles? Or?
Attached thumbnail(s) |
gothspeed |
May 5 2013, 11:03 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
how much bigger are the bearings? Is the offset otherwise ok? Looks like you might need 911 spindles to match your 'larger' hubs.
Eric_Shea |
May 5 2013, 11:12 AM
You cannot put a 911 hub and rotor on a 914.
Read up here: http://www.914world.com/bbs2/index.php?showtopic=105728 |
Elliot Cannon |
May 5 2013, 11:29 AM
I just did this. I replaced the whole thing.
Eric_Shea |
May 5 2013, 11:35 AM
(IMG:style_emoticons/default/agree.gif) you need 911 struts at this point. So...
New Struts New Inserts New Calipers Or, some drilled -4 rotors. I "might" have one pair left in late style. |
viaverde |
May 6 2013, 12:20 PM
how much bigger are the bearings? Is the offset otherwise ok? Looks like you might need 911 spindles to match your 'larger' hubs. Much larger....looks as if I will be purchasing some 911 spindles...man I thought it was going to be a bolt on....with the rear, I received the entire swing arm assembly, so I'm not as concerned... |
viaverde |
May 6 2013, 12:22 PM
SLITS |
May 6 2013, 01:02 PM
PM sent
Lo-Fi Version | Time is now: 20th May 2024 - 10:24 PM |
