QUOTE(gothspeed @ May 5 2013, 10:03 AM)
how much bigger are the bearings? Is the offset otherwise ok? Looks like you might need 911 spindles to match your 'larger' hubs.
Much larger....looks as if I will be purchasing some 911 spindles...man I thought it was going to be a bolt on....with the rear, I received the entire swing arm assembly, so I'm not as concerned...
